tado Smart Radiator Thermostat - Duo Pack - Vertical Mounting
Quicklinx: FLQXWS00 Mfr#: V3P-2SRT01V-TC-ML
The smart way to control your heating in individual rooms
Never heat your whole home again! tado° Smart Radiator Thermostats can replace your existing thermostatic radiator valves and provide room-by-room scheduling and control, so you can enjoy greater comfort and improve the efficiency of your heating system.
To benefit from tado° Smart Radiator Thermostats, you must also install a tado° Starter Kit.
Easy to install
This product can be easily self-installed - simply unscrew your existing thermostatic radiator valve, replace this with a tado° Smart Radiator Thermostat (using one of the 6 adaptors provided if required), and add the device in your tado° app.
Easy to use
The highly rated tado° app enables you to individually schedule and control each Smart Radiator Thermostat from anywhere, as well as providing insights and reports about the climate of individual rooms and showing you the energy savings made by tado°.
tado° is also compatible with Amazon Alexa, Apple HomeKit and Google Assistant, meaning you can control your heating in each room where you have a Smart Radiator Thermostat, using your voice, as well as integrating them into routines with your other smart home devices.
tado° Smart Radiator Thermostats are available to purchase in single, duo and quattro packs.
In the box:
- 2 x tado° Smart Radiator Thermostat
- 2 x 2 AA batteries
- 2 x Set of adaptors
  • Ideal for communal heating
    Smart control of your radiators even if you do not have your own boiler.
  • More comfort
    Individually control multiple radiators for maximum comfort.
tado° Smart Radiator Thermostat - vertical - radiator thermostat - matt white (pack of 2)
Radiator thermostat
Packaged Quantity
2 (specifications are for single item)
Functions
Control heating systems
Integrated Sensors
Humidity, temperature
Power Source
Intelligent Assistant
Google Assistant, Alexa
Wireless
Frequency Band
868 MHz
Display
LED
Matt white
5.2 cm x 5.2 cm x 7.8 cm
Packaged Quantity
Radiator thermostat
Functions
Integrated Sensors
Power Source
Wireless
Frequency Band
868 MHz
Display
LED
Light sensor
Internet of Things (IoT)
Compatible Services
IFTTT
Thermostat
Matrix display
Aerial
Internal
AA type
Battery Included
Required Qty
2
6 radiator adapters
Product Material
Polycarbonate, ABS plastic
Matt white
Encryption Algorithm
AES-CCM, 2048-bit SSL, 256-bit SSL, TLS 1.2
Warranty
ISO 9001, ISO 14001, RoHS, OHSAS 18001
5.2 cm
5.2 cm
7.8 cm
110 g
Shipping Width
17.4 cm
Shipping Depth
7 cm
Shipping Height
17.4 cm
Shipping Weight
604 g
