tado Additional Smart Radiator Thermostat - Vertical
Quicklinx: CWD6WS00 Mfr#: SRT01V-TC-ML-03
The smart way to control your heating in individual rooms
Never heat your whole home again! tado° Smart Radiator Thermostats can replace your existing thermostatic radiator valves and provide room-by-room scheduling and control, so you can enjoy greater comfort and improve the efficiency of your heating system.
To benefit from tado° Smart Radiator Thermostats, you must also install a tado° Starter Kit.
Easy to install
This product can be easily self-installed - simply unscrew your existing thermostatic radiator valve, replace this with a tado° Smart Radiator Thermostat (using one of the 6 adaptors provided if required), and add the device in your tado° app.
Easy to use
The highly rated tado° app enables you to individually schedule and control each Smart Radiator Thermostat from anywhere, as well as providing insights and reports about the climate of individual rooms and showing you the energy savings made by tado°.
tado° is also compatible with Amazon Alexa, Apple HomeKit and Google Assistant, meaning you can control your heating in each room where you have a Smart Radiator Thermostat, using your voice, as well as integrating them into routines with your other smart home devices.
tado° Smart Radiator Thermostats are available to purchase in single, duo and quattro packs.
In the box:
- tado° Smart Radiator Thermostat
- 2 AA batteries
- Set of adaptors (6 per set)
  • Ideal for communal heating
    Smart control of your radiators even if you do not have your own boiler.
  • More comfort
    Individually control multiple radiators for maximum comfort.
Wireless
Wireless
Encryption Algorithm
AES-CCM, 2048-bit SSL, 256-bit SSL, TLS 1.2
