Synology VS960HD VisualStation
Quicklinx: D47NWS00 Mfr#: VS960HD
Sometimes for routine surveillance at a store counter or at an office front desk a pricey dedicated computer is not necessary or simply cannot be accommodated. In these circumstances, Synology Visual Station is your optimal alternative as it is energy-efficient, cost-effective and really flexible.
  • PC-less Surveillance Management solution
    VisualStation is the perfect alternative when facing limited space or budget constraints. Just plug in an Ethernet cable, connect to an LCD-monitor or TV, log in to Synology Surveillance Station - and you have a monitoring station for yourself.
  • Dual screen display
    By supporting dual monitor video outputs to allow users to switch between mirrored and extended desktop modes, VisualStation provides a cost-efficient, easy to setup, and scalable TV wall solution.
  • Minimum device size
    The whole system fits in a palm-sized enclosure and can be easily attached to a wall or the back of a screen with a VESA compatible mount.
  • Convenient live view and playback interface
    VS960HD provides a user-friendly interface and powerful features from Surveillance Station.
  • Intuitive interface for easy operation
    For both beginner and advanced users, you can enjoy versatile features by operating VisualStation directly via an intuitive interface using a USB mouse, keyboard, or even a joystick.
Synology Visual Station VS960HD - standalone NVR - 96 channels
NVR - 96 channels - networked
IP Cameras Supported
96
Compression Format
MJPEG, MPEG-4, H.264, H.265
Image Resolution
1280x720, 1920x1080, 2048x1536, 2591x1944, 3840x2160
Voltage
100 - 240 V
13 cm x 13 cm x 3.2 cm
380 g
3 years
NVR
Video Channels
96
96
Image Resolution
Compression Format
Package Content
NVR, external power adapter, wall mount kit
Network cable - RJ-45 - RJ-45 - 1 pcs.
EN50155, FCC Class B certified, BSMI Class B, EN 45545
Warranty
3 years
Security DVR
Networked
Video Output Ports
HDMI x 2
Audio Input Ports
Mini-phone stereo 3.5 mm x 1
Audio Output Ports
Network Port
10/100/1000Base-T
Other Ports
USB 2.0 x 2, USB 3.0 x 1
Voltage
100 - 240 V
Frequency
50/60 Hz
Power Consumption
7.2 Watt
13 cm
13 cm
3.2 cm
380 g
-20 °C
50 °C
5 - 95% (non-condensing)
