Synology RX415 delivers an effortless volume expansion and data backup solution for Synology's 1U RackStation servers by providing an additional 4 drive slots. With its short-depth chassis design, RX415 ensures easy installation and deployment in 2-post racks and wall mount racks.
Volume expansion & backup
When drive capacity is running low on a Synology 1U RackStation, Synology RX415 provides an easy way to immediately scale capacity by providing an additional 4 slots. A RAID volume on the Synology RackStation can be expanded directly without having to reformat the existing drives, ensuring the Synology RackStation continues providing services during capacity expansion. Synology RX415 can serve as a dedicated local backup solution for a Synology RackStation. When created as a separate volume, the Synology RX415 provides a great backup solution for local drives in case of system failure. -
Reliable plug-and-use and short-depth chassis design
RX415 securely connects to Synology's 1U RackStation servers with a specially designed eSATA cable, ensuring easy connection and maximum data throughput. With its exceptional 12-inches short-depth chassis design, RX415 can be deployed in both industrial standard environments and smaller server rooms with limited space. Optional Synology Rail Kits are also available for easy system maintenance. -
Green & easy to manage
Deep Sleep can be manually configured to start automatically when the system has been inactive for a period of time. This not only saves energy but also extends the lifespan of hard drives. RX415 will also smartly power on/off with the attached RackStation, so no user intervention is needed to keep this system running smartly and efficiently.
- Synology RX415 - storage enclosure - TAA Compliant
- Storage enclosure
- Enclosure Type
- Rack-mountable - 1U
- Total Array Capacity
- 4 TB
- Installed Devices / Modules Qty
- 4 (installed) / 4 (max)
- Supported Drives
- SATA-600
- Hard Drive
- 4 x 1 TB HDD - hot-swap
- Power
- AC 120/230 V - 50/60 Hz
- TAA Compliant
- 43.05 cm x 29 cm x 4.4 cm
- 4.23 kg
- 3-year warranty
- Storage enclosure
- Enclosure Type
Chassis
- 4
- Supported Devices / Modules Qty
- 4
- Supported Drives
- SATA-600
Storage
- 4 TB
- CPU
- No CPU
Hard Drive
- HDD - hot-swap
- Capacity
- 4 x 1 TB
- Expansion Bays
- 4 (total) / 0 (free) x hot-swap - 2.5" / 3.5" shared
- 1 x eSATA - 7 pin external Serial ATA
- Built-in 3 cooling fans
- Cables Included
- 1 x eSATA cable
- FCC Class B certified, RoHS, BSMI Class B
- TAA Compliant
- Power Device
- Internal power supply
- Voltage Required
- Power Provided
- 150 Watt
- 43.05 cm
- 29 cm
- 4.4 cm
- 4.23 kg
- Limited warranty - 3 years
- 5 °C
- 35 °C
- 5 - 95%
