Designed for growing businesses, this powerful network-attached storage solution features schedulable snapshots and resilient data integrity, on-the-fly scalability, as well as reliable performance required by modern workplaces. When dealing with large-scale data storage, businesses require a solution that offers reliable backup and prevents file corruption. This NAS server ensures information is stored with a high level of data integrity, while providing flexible and efficient data protection tools. Snapshots preserve the history of a shared folder allowing you to save a significant amount of backup copies for point-in-time recovery. Snapshots can be automatically captured up to every 5 minutes, without noticeably impacting system performance. By generating checksums for files and metadata, the system can automatically detect and attempt to repair corrupted data or report errors to the administrator. With Btrfs, you can specify a storage limit for each shared folder, making it possible to precisely control space consumption.
Perfect data protection and integrity
When dealing with large-scale data storage, businesses require a solution that offers reliable backup and prevents file corruption. This NAS server ensures information is stored with a high level of data integrity, while providing flexible and efficient data protection tools. -
Fast and efficient snapshots
Snapshots preserve the history of a shared folder allowing you to save a significant amount of backup copies for point-in-time recovery. Snapshots can be automatically captured up to every 5 minutes, without noticeably impacting system performance. -
Corruption detection and correction
By generating checksums for files and metadata, the system can automatically detect and attempt to repair corrupted data or report errors to the administrator. -
Customizable quotas for shared folders
With Btrfs, you can specify a storage limit for each shared folder, making it possible to precisely control space consumption. -
Powerful processor for speedy performance
This NAS server is powered by the efficient processor running at 2.4 GHz. It delivers blazing-fast performance. This kind of power makes it easy for this server to run multiple applications and deliver consistently high throughput to all connected clients. -
Redundancy mechanisms for higher uptime
This NAS server includes redundant hardware mechanisms to ensure business continuity. The built-in Ethernet ports with link aggregation and failover provide reliability in the event of unexpected hardware failure, while the hot-swappable drives to minimize system downtime during drive replacement. -
Protection by LUN backup, snapshot, and clone
This NAS server enhances the ease of moving and copying data in a virtualized environment with the backup, snapshot, and clone. -
All-in-one server
With just one server it's possible to handle a vast amount of tasks. It helps your company to gain a competitive edge by acting as your multifunction server. -
Secure your data
It offers advanced security measures to protect you from potential security holes.
- Synology RackStation RS2416+ - NAS server - 72 TB - TAA Compliant
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Enclosure Type
- Rack-mountable - 2U
- Total Storage Capacity
- 72 TB
- Max Supported Capacity
- 96 TB
- Installed Devices / Modules Qty
- 12 (installed) / 12 (max)
- 43 cm x 69.2 cm x 8.8 cm
- 12.56 kg ()
- Processor
- 1 x Intel Atom C2358 1.7 GHz (Dual-Core)
- Storage Controller
- RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD
- Hard Drive
- 12 x 6 TB
- Networking
- 10Mb LAN, 100Mb LAN, GigE
- IP Cameras Supported
- 40
- RAM
- 2 GB
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Microsoft Windows XP or later, Apple MacOS X 10.5 or later, Ubuntu 9.04 or later
- TAA Compliant
- 3-year warranty
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Enclosure Type
- 72 TB
- 96 TB
- 43 cm
- 69.2 cm
- 8.8 cm
- 12.56 kg ()
Processor / Memory
- Processors Installed
- Number of Cores
- Dual-Core
- Max Supported Qty
- 1
- RAM
- 2 GB (installed) / 6 GB (supported) - DDR3
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Hard Drive
- HDD - hot-swap
- Capacity
- 12 x 6 TB
- Data Link Protocol
- PPTP, L2TP, iSCSI, FTP, NFS
- Remote Management Protocol
- SNMP, Telnet, SSH
- Network Services Compatibility
- Microsoft Active Directory (AD), Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV)
- LDAP support, wake on LAN (WOL), Syslog support, antivirus analysis, video server, Access Control List (ACL) support, e-mail server, surveillance station, cloud backup, VPN Server
- Encryption Algorithm
- SSL, TLS
Security DVR
- 40
- Compression Format
- MJPEG, H.264
- Image Resolution
- 1280x720, 1920x1080, 2048x1536, 2591x1944
- Expansion Bays
- 12 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
- 4 x Ethernet 1000Base-T - RJ-45 , 2 x USB 2.0 - Type A , 2 x USB 3.0 - Type A , 1 x management
- Built-in 4 cooling fans
- FCC Class A certified, RoHS, BSMI Class A
- TAA Compliant
- Power Device
- Internal power supply
- Installed Qty
- 1
- Max Supported Qty
- 1
- Voltage Required
- Power Provided
- 500 Watt
- OS Required
- TAA Compliant
- Limited warranty - 3 years
- 5 °C
- 35 °C
- 5 - 95%
- Sound Emission
- 41.5 dBA
