Synology RackStation RS214 is a 1U 2-bay rackmount NAS. Featuring easy data sharing and management, RS214 is a genuine value specifically designed to serve growing businesses of any size. With Synology's rich office applications, RS214 is dedicated to enhance working experience and productivity.
Optimal price/performance ratio
Synology RS214 is an affordable and reliable solution for a growing business of any size. The built-in floating-point unit enhances the overall capability of the main CPU, enabling higher working efficiency. Synology RS214 delivers an average over 70 MB/sec writing speed under RAID 1 configuration in a Windows environment, and over 100 MB/sec reading. With RAM twice the size of its predecessor, RS214 exhibits a surprising boost in multi-tasking performance, making it one of the best values in 2-bay rackmount NAS devices available today. Designed with attention to recovery mechanism, RS214 comes with dual LAN failover support to ensure continual network service in case of LAN failure, while hot-swappable design facilitates easy and risk-free hard drive replacement. -
Compact design in 12-inch depth
Synology RS214, a 1U 2-bay rackmount NAS server with exceptional 12 inches in depth, offers an affordable and comprehensive solution for both industrial standard environments and smaller server rooms with limited space. Its compact size fits perfectly into 2-position rack and wall mount rack without additional rail kit. It is also resilient enough to withstand operating temperature up to 45°C/110°F, offering high reliability under extreme conditions. The smart fan design keeps Synology RS214's fan spinning at a very low speed, quiet your rack to create a calmer office working environment. -
Effective backup solution
Synology RS214 offers a centralized backup target to consolidate fragmented and unstructured data across a network. A backup wizard is provided for backing up data from Synology RS214 to another Synology NAS, to other rsync server, or to an external drive. Backing up to Amazon S3 and Glacier cloud service is also supported. The add-on package, Time Backup, keeps DiskStation data in multiple versions, so IT administrators could easily keep track of them and restore to a previous version whenever required. -
Energy efficient and environmentally friendly
Synology RackStations are designed and developed with attention to energy efficiency. Compared with the average PC counterparts, Synology RS214 consumes very low wattage in operation. All Synology products are produced with RoHS compliant parts and packed with recyclable packing materials. Synology acknowledges the responsibility as a global citizen to continually work to reduce the environmental impact of every product produced.
- Synology RackStation RS214 - NAS server - 16 TB - TAA Compliant
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Enclosure Type
- Rack-mountable - 1U
- Total Storage Capacity
- 16 TB
- Max Supported Capacity
- 16 TB
- Installed Devices / Modules Qty
- 2 (installed) / 2 (max)
- 43.05 cm x 28.75 cm x 4.4 cm
- 3.14 kg ()
- Localisation
- Danish, Hungarian, Czech, Chinese (traditional), Chinese (simplified), Brazilian Portuguese, English, German, French, Italian, Norwegian, Portuguese, Polish, Swedish, Russian, Spanish, Dutch, Turkish, Japanese, Korean
- Processor
- 1 x Marvell ARMADA 370 1.2 GHz
- Storage Controller
- RAID SATA 6Gb/s RAID RAID 0, 1, JBOD
- Hard Drive
- 2 x 8 TB
- Networking
- 10Mb LAN, 100Mb LAN, GigE
- IP Cameras Supported
- 8
- RAM
- 512 MB
- Power
- AC 120/230 V (50/60 Hz)
- Storage Operating System
- Synology DiskStation Manager
- System Requirements
- Microsoft Windows XP or later, Apple MacOS X 10.5 or later, Ubuntu 9.04 or later
- TAA Compliant
- 3-year warranty
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Enclosure Type
- 16 TB
- 16 TB
- 43.05 cm
- 28.75 cm
- 4.4 cm
- 3.14 kg ()
- Built-in Devices
- Led panel
- Localisation
Processor / Memory
- Processors Installed
- Max Supported Qty
- 1
- RAM
- 512 MB DDR3
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s
- RAID Level
- RAID 0, RAID 1, JBOD
Hard Drive
- HDD - hot-swap
- Capacity
- 2 x 8 TB
- Data Link Protocol
- PPTP, L2TP, iSCSI, LPR/LPD, SMTP, FTP, DHCP, POP3, IMAP
- Remote Management Protocol
- SNMP, Telnet, IPP, HTTP, HTTPS, SSH
- Network Services Compatibility
- Microsoft Active Directory (AD), Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
- Firewall protection, VPN support, LDAP support, VLAN support, wake on LAN (WOL), Syslog support, E-mail alert, print server, IPv6 support, MySQL server, web server, backup server, download client, file sharing, Access Control List (ACL) support, Advanced Data Streaming (ADS), SSH support, iTunes server, DHCP server, Samba support, FTP server, SMS alert, BitTorrent Client, e-mail server, UPnP Media Server, bandwidth control, surveillance station, DLNA Media Server, eMule client, e-mail notification, VPN Server
- Encryption Algorithm
- SSL, TLS
- DLNA CERTIFIED, UPnP
Security DVR
- 8
- Expansion Bays
- 2 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
- 2 x Ethernet 1000Base-T - RJ-45 , 2 x USB 3.0 - Type A , 2 x USB 2.0 - Type A , 1 x eSATA 3Gb/s , 1 x management - DB-9
- Built-in 3 cooling fans, LED indicator, Google Cloud Print, hardware encryption
- FCC Class A certified, RoHS, BSMI Class A
- TAA Compliant
- Power Device
- Internal power supply
- Voltage Required
- 25.8 Watt
- Power Provided
- 100 Watt
- Software Included
- Synology Assistant, Synology Data Replicator 3
- OS Required
- TAA Compliant
- Limited warranty - 3 years
- 0 °C
- 45 °C
- 5 - 95%
- Sound Emission
- 28.8 dBA
