Synology FS3017 24 Bay 2U All-Flash Rackmount NAS Enclosure
Quicklinx: CL29WS00 Mfr#: FS3017
  • Xeon
Enterprises are now challenged to handle I/O-intensive and latency sensitive applications, whether it’s managing large raw files, virtual machines or databases, FS3017 is an easy to maintain, affordable, yet powerful all-flash NAS solution for businesses.
Cost-effective flexibility
Due to vendor lock-in, all-flash storage is notoriously expensive, but FS3017 accepts both high-end SAS SSD and the more mainstream SATA SSD. Raw capacity of FS3017 reaches 90TB.
No more bottlenecks
High-latency and low random IOPS is the bane of a regular storage array. Dealing with an unresponsive infrastructure is both costly and frustrating. FS3017 delivers a massive iSCSI 200,000 4K random write IOPS, thanks to its dual 6-core Xeon processor and 64GB of DDR4 ECC memory with NUMA integration. Upgrade the RAM up to 512GB for even more powerful performance.
RAID F1
When building RAID arrays with SSDs, it’s very common for the disks to all wear out at the same time, due to the evenly distributed workload. With RAID F1, one system-assigned SSD takes the heat for the rest, handling the most write-intensive operations, and is worn out before the other SSDs. This process allows the users time to switch out the single dead disk, instead of risking multiple SSD failures at once.
Future-proof networking
FS3017 is equipped with two 10GBase-T ports. If you need more horsepower, FS3017 also has two PCIe slots available for adding more Ethernet controllers. Choose between 10GbE, 25GbE, and 40GbE to unlock FS3017’s full potential. In addition, you can leverage iSCSI over RDMA technology to enhance iSCSI performance by up to 80% with an optional purchase of supported NIC on FS3017.
Data Protection & Disaster Recovery
The built-in Snapshot Replication application reproduces 65,000 backup copies to offsite servers, bringing near-instantaneous data protection and ensuring data in shared folders or virtual machines in iSCSI LUNs remain available in the event of disaster.
Supports VMware vSphere, Windows Server, Citrix XenServer, and OpenStack Cinder
Synology iSCSI storage fully supports all major virtualization solutions, from VMware, Windows, Citrix, to OpenStack Cinder. Simplify your recovery process with VMware Site Recovery Manager, and initiate disaster recoveries directly via VMware vCenter Server.
  • Cost-effective flexibility
  • RAID F1
    Due to the peculiarities of SSD and RAID technology, a common challenge lies in how to prevent all of the drives from failing at the same time because of the evenly distributed workload. RAID F1 alleviates this problem with a specially designed algorithm to unevenly distribute workload to drives, enhancing the resilience of the storage pool and ensuring your data remains safe.
  • Future-proof networking
Synology FlashStation FS3017 - NAS server
NAS server
Host Connectivity
10 Gigabit Ethernet
Enclosure Type
Rack-mountable - 2U
0 (installed) / 24 (max)
48.2 cm x 72.4 cm x 8.8 cm
17.13 kg ()
2 x Intel Xeon E5-2620V3 2.4 GHz (6-core)
Storage Controller
RAID RAID RAID 0, 1, 5, 6, 10, JBOD, RAID F1
10Mb LAN, 100Mb LAN, 1GbE, 10GbE, iSCSI
IP Cameras Supported
100
Performance
iSCSI 4K random write IOPS: over 200000
RAM
64 GB
AC 100-240 V (50/60 Hz)
Power Redundancy
5-year warranty
NAS server
Host Connectivity
10 Gigabit Ethernet
Enclosure Type
Rack-mountable - 2U
Total Storage Capacity
0 GB
48.2 cm
72.4 cm
8.8 cm
17.13 kg ()
Processor / Memory
Processors Installed
Number of Cores
6-core
Max Supported Qty
2
RAM
64 GB (installed) / 512 GB (supported) - DDR4
ECC
Storage Controller
RAID
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID F1
Network / Transport Protocol
iSCSI, SMB
Remote Management Protocol
SNMP, Telnet, SSH
Network Services Compatibility
Microsoft CIFS, Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
Performance
Wake on LAN (WOL), High Availability, anti-malware protection, Access Control List (ACL) support, FTP server, reset button, bandwidth control, Traffic Control, e-mail notification, VPN Server, Link Aggregation, failover protection, OpenStack compatible, Disaster Recovery technology, B-tree file system (Btrfs), EXT4 file system, iSCSI LUN clone/snapshot, Windows ODX, cloud station server, MailPlus server, L2TP support
Encryption Algorithm
AES-NI
Security DVR
100
Compression Format
MJPEG, H.264, H.265
Image Resolution
1280x720, 1920x1080, 2048x1536, 2591x1944, 3840x2160
Expansion Bays
24 (total) / 24 (free) x hot-swap - 2.5"
Expansion Slots
1 (total) / 1 (free) x PCI Express 3.0 x8 , 1 (total) / 1 (free) x PCI Express 3.0 x16
2 x USB 3.0 - Type A , 2 x Ethernet 10Gb - RJ-45 , 1 x serial - DB-9
Automatic fan speed control, built-in 4 cooling fans, hardware encryption, scheduled power on/off, S.M.A.R.T. support
FCC Class A certified, RoHS, BSMI Class A
Accessory pack
Internal power supply
Installed Qty
2
Max Supported Qty
2
Power Redundancy
Limited warranty - 5 years
5 °C
35 °C
5 - 95% RH
