Synology DX510 delivers an effortless solution for volume expansion and data backup for selected Synology DiskStations. The DX510 smoothly scales the storage capacity of the Synology DiskStation by an additional 5 hard drives on the fly when firmly connected directly to the Synology DiskStation, ensuring a reliable expansion solution.
Volume expansion and backup
When running out of the hard drive capacity on the Synology DiskStation, the Synology DX510 provides an easy way to immediately scale capacity by an additional 5 hard drives. The RAID volume on the Synology DiskStation can be expanded directly without having to reformat the existing hard drives, ensuring the Synology DiskStation continues its service during the capacity expansion. When created as a separate volume, the Synology DX510 provides a great solution for backing up the Synology DiskStation. -
Reliable plug-and-use design
The Synology DX510 is connected to the Synology DiskStation using an eSATA cable with custom-designed connectors on both ends, ensuring a reliable connection and maximum throughput. The eSATA 3.0 Gb/sec definition allows the hard drives in the connected Synology DX510 to operate as they are the internal ones of the Synology DiskStation. -
Green and easy to manage
The HDD hibernation can be manually configured to take effect automatically when the system has been inactive for a period of time. This not only save energy but also extends the lifespan of the hard disk. Synology DX510 is managed with the DiskStation firmware Synology DSM 2.3. No firmware installation is needed.
- Synology DX510 - hard drive array - TAA Compliant
- Hard drive array
- Interface
- SATA 3Gb/s
- Installed Devices / Modules Qty
- 5 (max)
- Supported Drives
- SATA-300
- Storage Controller
- RAID (SATA 3Gb/s) - RAID 0, 1, 5, 6, 10, JBOD, 5 hot spare
- Hard Drive
- 0 HDD - hot-swap
- Power
- AC 120/230 V - 50/60 Hz
- TAA Compliant
- 15.7 cm x 24.8 cm x 23.3 cm
- 4.1 kg
- 3-year warranty
- Designed For
- Disk Station DS1010+, DS1511+, DS1512+, DS1812+, DS710+, DS712+
- Hard drive array
Chassis
- Supported Devices / Modules Qty
- 5
- Supported Drives
- SATA-300
Storage
- HDD Array External Interface
- SATA 3Gb/s
Storage Controller
- RAID
- Interface Type
- SATA 3Gb/s
- Data Transfer Rate
- 300 MBps
- Supported Devices
- Disk array (RAID)
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID 5 hot spare
Hard Drive
- HDD - hot-swap
- Capacity
- 0
- Expansion Bays
- 5 (total) / 5 (free) x hot-swap
- 1 x SATA 3Gb/s - 7 pin external Serial ATA
- Cables Included
- 1 x eSATA cable
- Mounting Kit
- Included
- RoHS
- TAA Compliant
- Power Device
- Internal power supply
- Voltage Required
- 15.7 cm
- 24.8 cm
- 23.3 cm
- 4.1 kg
- Limited warranty - 3 years
- 5 °C
- 35 °C
- 5 - 95%
- Designed For
- Synology Disk Station DS1010+, DS1511+, DS1512+, DS1812+, DS710+, DS712+
