Synology DX213 12TB-Red 2 Bay NAS
Quicklinx: B0HRWS00 Mfr#: DX213/12TB-RED
Synology DX213 delivers an effortless solution for volume expansion and data backup for selected Synology DiskStation models. The DX213 seamlessly scales up the storage capacity of the DiskStation by additional 2 hard drives on-the-fly when connected directly to an expansion cable.
  • Volume expansion and backup
    When running out of hard drive capacity on the Synology DiskStation, Synology DX213 provides an easy way to immediately scale capacity by additional 2 hard drives. The RAID volume on the Synology DiskStation can be expanded directly without having to reformat the existing hard drives, ensuring the Synology DiskStation continues its service during the capacity expansion. Synology DX213 can be used as a dedicated local backup solution for the Synology DiskStation. When created as a separate volume, the Synology DX213 provides a great backup solution to its local hard disks in case of system failure.
  • Reliable plug-n-use design
    The Synology DX213 is connected to the Synology DiskStation using an expansion cable with custom-designed connectors on both ends, ensuring a reliable connection and maximum throughput. The 3.0 Gb/sec connection speed allows the hard drives in the connected Synology DX213 to operate as the internal ones of Synology DiskStation.
  • Green and easy to manage
    The HDD hibernation and system hibernation can be manually configured to take effect automatically when the system has been inactive for a period of time. This not only saves energy but also extends the lifespan of the hard disk. The DX213 will also smartly power on/off with the attached DiskStation, so no user intervention is needed to keep this system running smartly and efficiently.
Synology DX213 - hard drive array - TAA Compliant
Hard drive array
Total Array Capacity
12 TB
2 (installed) / 2 (max)
Storage Controller
RAID (SATA 6Gb/s) - RAID RAID 0, 1, JBOD
Hard Drive
2 x 6 TB NAS compatible
AC 120/230 V - 50 - 60 Hz
TAA Compliant
10 cm x 22.55 cm x 16.5 cm
870 g
Hard drive array
Chassis
2
Supported Devices / Modules Qty
2
Storage
12 TB
Storage Controller
RAID
Channel Qty
2
Interface Type
SATA 6Gb/s
Data Transfer Rate
600 MBps
RAID Level
RAID 0, RAID 1, JBOD
Hard Drive
2 x 6 TB
NAS compatible
Expansion Bays
2 (total) / 0 (free) x internal - 2.5" / 3.5" shared
Built-in cooling fan
1 x data cable
FCC Class B certified, RoHS, BSMI Class B
TAA Compliant
External power adapter
21 Watt
10 cm
22.55 cm
16.5 cm
870 g
5 °C
35 °C
5 - 95%
Sound Emission
19 dBA
