DS419slim is a 4-bay cube-shaped NAS providing on-the-go file access and sharing with secure file transfer. Ideal to serve as your clever and reliable partner, it keeps all your photos, video, and files well-organized.
Compact design
The Synology Disk Station DS419slim features a compact form factor, ideal for environments where space is limited. Its 2.5" hot-swap expansion bays offer flexibility and ease of maintenance. -
Robust data protection
Equipped with hardware encryption, the DS419slim keeps your data secure and protected. With support for multiple RAID levels, including RAID 0, RAID 1, RAID 10, RAID 5, and RAID 6, it provides options to protect your information against drive failures. -
Versatile connectivity
This NAS server includes two USB 3.0 ports and two Ethernet 1000Base-T ports, offering high-speed connections and flexible networking options. Suitable for home or office use, it ensures reliable access to your data. -
Comprehensive network services
From cloud backup to an iTunes server, the DS419slim supports a wide range of network services and protocols, including DLNA, UPnP, VPN, and more. It serves as a versatile server for file sharing, media streaming, and network surveillance. -
Energy efficient
With a power consumption of only 20 W during operation and 7 W on standby, the DS419slim is designed for energy efficiency. This not only helps reduce operating costs but also supports a more sustainable environment.
- Synology Disk Station DS419slim - NAS server
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Installed Devices / Modules Qty
- 0 (installed) / 4 (max)
- 10.5 cm x 14.2 cm x 12 cm
- 660 g ()
- Processor
- 1 x Marvell ARMADA 88F6820 1.33 GHz (Dual-Core)
- Storage Controller
- RAID SATA 6Gb/s RAID 0, 1, 5, 6, 10, JBOD
- Networking
- 10Mb LAN, 100Mb LAN, 1GbE
- RAM
- 512 MB
- Power
- AC 120/230 V
- Storage Operating System
- Synology DiskStation Manager
- 2-year warranty
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 0 GB
- 10.5 cm
- 14.2 cm
- 12 cm
- 660 g ()
Processor / Memory
- Processors Installed
- Number of Cores
- Dual-Core
- Max Supported Qty
- 1
- RAM
- 512 MB DDR3L
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
- Data Link Protocol
- L2TP
- Remote Management Protocol
- SNMP, HTTPS
- Network Services Compatibility
- Microsoft Active Directory (AD), Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
- LDAP support, WOL, print server, download client, ACL support, iTunes server, Samba support, FTP server, e-mail server, surveillance station, DLNA Media Server, Energy Efficient Ethernet, cloud backup, VPN Server, SNMP support, anti-virus protection, REP
- Encryption Algorithm
- SSL, TLS
- DLNA CERTIFIED, UPnP
- Expansion Bays
- 4 (total) / 4 (free) x hot-swap - 2.5"
- 2 x USB 3.0 - Type A , 2 x Ethernet 1000Base-T - RJ-45
- Cables Included
- 2 x network cable
- Security lock slot (cable lock sold separately), hardware encryption
- Security Slot Type
- Kensington security slot
- RoHS
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- 20 watt
- Power Consumption Stand by
- 7 watt
- Limited warranty - 2 years
- 5 °C
- 40 °C
- 5 - 95%
