Synology DiskStation DS416j is a 4-bay NAS server specifically designed for home and personal users to effectively manage, protect and share data. You can enjoy effortless data sharing, multimedia streaming and cloud synchronization features while keeping data safe and secure.
Synology DS416j is backed with Synology’s 2-year limited warranty.
Versatile storage options
The Synology Disk Station DS416j offers a range of RAID configurations, including RAID 0, RAID 1, RAID 10, RAID 5, and RAID 6, alongside JBOD. This flexibility allows users to tailor the storage performance and redundancy according to their specific needs, ensuring data is stored efficiently and securely. -
Comprehensive connectivity
Equipped with USB 3.0 for high-speed data transfer, Gigabit Ethernet for robust networking capabilities, and support for a variety of network protocols including FTP, SMTP, and IMAP, the DS416j ensures seamless connectivity and access to your data whenever you need it. -
Enhanced security features
With hardware encryption and a Kensington security slot, the Synology DS416j provides an added layer of security to protect your sensitive data. These features, combined with the device's comprehensive firewall protection and access control lists, ensure that your data remains safe from unauthorized access. -
Multimedia and server capabilities
The DS416j serves as a versatile server with DLNA CERTIFIED and UPnP media streaming, an iTunes server, surveillance station, and even a VPN Server. This makes it an ideal solution for managing and distributing multimedia content, as well as monitoring your environment. -
Efficient operation
Designed to operate within a wide range of temperatures (5°C to 40°C) and humidity (5 - 95%), coupled with Wake On LAN (WOL) functionality, the DS416j is built for efficient performance and reliability in various environments, ensuring your data is always accessible.
- Synology Disk Station DS416j - NAS server - 16 TB - TAA Compliant
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 16 TB
- Installed Devices / Modules Qty
- 4 (installed) / 4 (max)
- 16.8 cm x 23 cm x 18.4 cm
- 2.21 kg ()
- Processor
- 1 x Marvell 88F6828 1.3 GHz (Dual-Core)
- Storage Controller
- RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD
- Hard Drive
- 4 x 4 TB 24x7 continuous operation
- Networking
- 10Mb LAN, 100Mb LAN, GigE
- IP Cameras Supported
- 25
- RAM
- 512 MB
- Power
- AC 120/230 V (50/60 Hz)
- Storage Operating System
- Synology DiskStation Manager
- System Requirements
- Microsoft Windows XP or later, Apple MacOS X 10.7 or later, Ubuntu 12.x, Android 4.0 or later, Apple iOS 7 or later
- TAA Compliant
- 2-year warranty
- NAS server
- Host Connectivity
- Gigabit Ethernet
- 16 TB
- 16.8 cm
- 23 cm
- 18.4 cm
- 2.21 kg ()
Processor / Memory
- Processors Installed
- Number of Cores
- Dual-Core
- Max Supported Qty
- 1
- RAM
- 512 MB DDR3
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Hard Drive
- HDD
- Capacity
- 4 x 4 TB
- 24x7 continuous operation
- Data Link Protocol
- PPTP, L2TP, SMTP, POP3, IMAP
- Remote Management Protocol
- SNMP, Telnet, HTTPS, SSH
- Network Services Compatibility
- Microsoft Active Directory (AD), Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
- Firewall protection, wake on LAN (WOL), download client, Access Control List (ACL) support, SSH support, iTunes server, Samba support, FTP server, bandwidth control, surveillance station, Energy Efficient Ethernet, VPN Server, automated backup scheduling, Wi-Fi USB dongle support
- DLNA CERTIFIED, UPnP
Security DVR
- 25
- Expansion Bays
- 4 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
- 1 x USB 2.0 - Type A , 1 x USB 3.0 - Type A , 1 x Ethernet 1000Base-T - RJ-45
- Cables Included
- 2 x network cable
- Security lock slot (cable lock sold separately), built-in cooling fan, hardware encryption, 24x7 continuous operation
- Security Slot Type
- Kensington security slot
- TAA Compliant
- Power Device
- External power adapter
- Voltage Required
- Software Included
- Drivers & Utilities
- OS Required
- TAA Compliant
- Limited warranty - 2 years
- 5 °C
- 40 °C
- 5 - 95%
