Backup all your digital assets with Synology DS218j, a powerful 2-bay NAS with rapid data transmission and low power consumption, designed for home users.
Efficient storage management
The Synology Disk Station DS218j offers Hybrid RAID technology, allowing for flexible and efficient management of data storage with options for RAID 0, RAID 1, and JBOD configurations. This versatility ensures optimal performance and data protection for various use cases. -
Robust security features
Equipped with hardware encryption, SSL, and TLS algorithms, the DS218j provides a secure environment for data storage and transmission. The inclusion of a Kensington security slot further enhances physical security, making it a reliable choice for sensitive data. -
Comprehensive networking capabilities
With support for multiple data link protocols including Ethernet, Fast Ethernet, and Gigabit Ethernet, along with a wide range of network services compatibility such as AFP, NFS, SMB, and iSCSI, the DS218j ensures seamless integration into any network environment. Its VPN support and firewall protection offer secure remote access and data safety. -
Advanced media and server support
The DS218j shines as a versatile server with DLNA CERTIFIED compliance, an iTunes server, FTP server, and more. It supports various network protocols and services, making it an ideal solution for hosting multimedia content, file sharing, and other server-based applications. -
Durable and eco-friendly design
Designed with a built-in cooling fan and operating within a wide temperature range of 5°C to 40°C, the DS218j is built for reliability. Its compliance with RoHS standards underscores Synology's commitment to environmental sustainability.
- Synology Disk Station DS218j - NAS server - 8 TB
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 8 TB
- Installed Devices / Modules Qty
- 2 (installed) / 2 (max)
- 10 cm x 22.55 cm x 16.5 cm
- 870 g ()
- Processor
- 1 x Marvell ARMADA 385 1.3 GHz (Dual-Core)
- Storage Controller
- RAID SATA 6Gb/s RAID RAID 0, 1, JBOD
- Hard Drive
- 2 x 4 TB
- Networking
- 10Mb LAN, 100Mb LAN, 1GbE
- IP Cameras Supported
- 14
- RAM
- 512 MB
- Power
- AC 120/230 V (50/60 Hz)
- 2-year warranty
- NAS server
- Host Connectivity
- Gigabit Ethernet
- 8 TB
- 10 cm
- 22.55 cm
- 16.5 cm
- 870 g ()
Processor / Memory
- Processors Installed
- Number of Cores
- Dual-Core
- Max Supported Qty
- 1
- RAM
- 512 MB DDR3
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s
- RAID Level
- RAID 0, RAID 1, JBOD
Hard Drive
- HDD
- Capacity
- 2 x 4 TB
- Data Link Protocol
- PPTP, L2TP, IPSec, iSCSI, FTP, SMB, NFS, SFTP
- Remote Management Protocol
- SNMP, Telnet, HTTP, HTTPS, SSH
- Network Services Compatibility
- Microsoft Active Directory (AD), Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
- Firewall protection, Access Control List (ACL) support, iTunes server, FTP server, reset button, PXE support, DNS server, VPN Server
- Encryption Algorithm
- SSL, TLS
- DLNA CERTIFIED
Security DVR
- 14
- Compression Format
- H.264
- Expansion Bays
- 2 (total) / 0 (free) x internal - 2.5" / 3.5"
- 2 x USB 3.0 - Type A , 1 x Ethernet 1000Base-T - RJ-45
- Cables Included
- 1 x network cable
- Security lock slot (cable lock sold separately), wake on LAN, built-in cooling fan, hardware encryption, Hybrid RAID, VPN support
- Security Slot Type
- Kensington security slot
- RoHS
- Power Device
- External power adapter
- Voltage Required
- Limited warranty - 2 years
- 5 °C
- 40 °C
- 5 - 95%
