DS1618+ is a 6-bay NAS that provides storage scalability perfect for tech enthusiasts and small- to medium-sized businesses by effortlessly handling workloads.
Supercharge your storage with speedy performance
DS1618+ comes with a PCIe expansion slot to support add-in cards. Install a dual M.2 SSD card for high-IOPS system caching. -
Ultimate file management and sharing
The Disk Station has a web-based, fast and secure management tool built to allow easy, drag-and-drop operation without requiring any complex setup on Mac or PC. Advanced search and filtering tools allow for easy organization and sharing of files with just a link. -
Ultimate backup solution
DS1618+ integrates various backup applications to safeguard your important data on any device with an intuitive user interface and durable storage technologies.
- Synology Disk Station DS1618+ - NAS server - 24 TB
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 24 TB
- Max Supported Capacity
- 72 TB
- Installed Devices / Modules Qty
- 6 (installed) / 6 (max)
- 28.2 cm x 24.3 cm x 16.6 cm
- Processor
- 1 x Intel Atom C3538 2.1 GHz (Quad-Core)
- Storage Controller
- RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD
- Hard Drive
- 6 x 4 TB
- Networking
- 10Mb LAN, 100Mb LAN, 1GbE
- IP Cameras Supported
- 40
- RAM
- 4 GB
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Apple MacOS X 10.11 or later, Microsoft Windows 7 / 10
- 3-year warranty
- NAS server
- Host Connectivity
- Gigabit Ethernet
- 24 TB
- 72 TB
- 28.2 cm
- 24.3 cm
- 16.6 cm
- Built-in Devices
- Led panel
Processor / Memory
- Processors Installed
- Number of Cores
- Quad-Core
- RAM
- 4 GB (installed) / 32 GB (supported) - DDR4
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Hard Drive
- HDD - hot-swap
- Capacity
- 6 x 4 TB
- Data Link Protocol
- TCP/IP, PPTP, L2TP, iSCSI, FTP, SMB, SFTP
- Remote Management Protocol
- SNMP, Telnet, HTTP, HTTPS, TFTP, SSH
- Network Services Compatibility
- Microsoft Active Directory (AD), File Level Security (ACLs), Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
- Hardware encryption, VPN support, wake on LAN (WOL), Syslog support, High Availability, download client, file sharing, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, surveillance station, PXE support, DLNA Media Server, Apple Time Machine compatible, WebDAV server, VPN Server, anti-virus protection, Link Aggregation, failover protection, DLNA support, OpenStack compatible, SSD trim, iSCSI LUN clone/snapshot, Windows ODX, cloud station server, MailPlus server, Rsync compatible, Synology Hybrid RAID
- Encryption Algorithm
- SSL, TLS, AES-NI
- DLNA CERTIFIED
Security DVR
- 40
- Compression Format
- MJPEG, H.264, H.265
- Image Resolution
- 1280x720, 1920x1080, 2048x1536, 2591x1944, 3840x2160
- Expansion Bays
- 6 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
- Expansion Slots
- 1 x PCI Express 3.0 x8
- 3 x USB 3.0 , 4 x Ethernet 1000Base-T - RJ-45 , 2 x eSATA
- Cables Included
- 2 x network cable
- Security lock slot (cable lock sold separately), wake on LAN, built-in 2 cooling fans, Citrix Ready, VMware Ready
- Security Slot Type
- Kensington security slot
- VCCI, BSMI, CCC, FCC, RoHS, EAC, RCM
- Power Device
- Internal power supply
- Voltage Required
- 56.86 Watt
- Power Consumption Stand by
- 25.76 Watt
- Power Provided
- 250 Watt
- Software Included
- McAfee AntiVirus (Trial)
- OS Required
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 5 - 95%
- Sound Emission
- 23.7 dBA
