Synology DS119J 10TB-RED (1 x 10TB) Bay NAS
Quicklinx: DYVFWS00 Mfr#: DS119J/10TB-RED
Marketing description is not available.
  • An ideal first NAS for everyone
    Synology DS119j is a 1-bay, entry-level network-attached storage specifically designed for personal users. Powered by a dual-core processor, DS119j delivers excellent sequential throughput at very high writing speed in a Windows environment. DS119j consumes only 10 watts during access and 5 watts during HDD hibernation. With the support of Wake-on-LAN and power schedule control, DS119j serves as a 24/7 personal storage server that is power-efficient and budget-friendly.
  • Easy setup and management
    Web Assistant is a web-based utility designed for users to easily set up their Synology NAS. System installation is done with your existing web browser in just a few simple steps. It is combined with a quick start widget, allowing users to simultaneously explore the DSM operating system and complete basic system settings. For users unfamiliar with router configurations, Synology EZ-Internet Wizard simplifies the process of setting up network access to DS119j by guiding users through network settings such as firewall, port-forwarding, PPPoE setup, and DDNS registration. Synology DiskStation DS119j is a budget-friendly, versatile and easy-to-use 1-bay NAS with the capability to host, share and protect data for personal users. DS119j offers a variety of packages in its DSM Package Center, allowing beginners to explore the infinite possibilities of Synology NAS.
  • Cross-platform file sharing and data synchronization
    Synology DS119j supports comprehensive network protocols, ensuring a seamless file sharing experience across Windows, Mac, and Linux platforms. Windows AD and LDAP integration allow DS119j to fit quickly and effortlessly into any existing network environment, without needing to create identical user accounts. Cloud Sync keeps your Dropbox, Google Drive, Microsoft OneDrive, Baidu, and Box storage in sync with your personal DiskStation at home. Cloud Station Suite allows you to sync files across Windows, macOS, Linux, and mobile devices, effortlessly keeping everything up-to-date. DS119j combines seamless file sharing capability with a high level of security, including HTTPS support, a built-in firewall, and multiple IP and account intrusion auto-blocking mechanisms.
  • Easy backup solutions
    Synology Hyper Backup provides multi-version backup with block-level incremental backup and cross-version deduplication. It optimizes storage utilization and allows data to be backed up to multiple destinations such as local shared folders, external hard drives, network shared folders, rsync servers, and public cloud services.
  • Running on Synology DiskStation Manager (DSM)
    DSM is a web-based operating system that provides private cloud services. It is designed to simplify your daily task management. The multitasking web interface allows you to run multiple applications simultaneously on one browser tab and instantly switch between them. The intuitive DSM allows you to effortlessly configure storage capacity, gives you complete control over your personal cloud, and lets you access your Synology NAS from anywhere. The built-in Package Center allows you to download and install the packages designed to satisfy different user needs, such as sharing files on the cloud, sharing photos on an online album, or setting up a VPN environment. Tasks can be done with just a few steps.
Synology Disk Station DS119j - personal cloud storage device - 10 TB
Personal cloud storage device
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
10 TB
1 (installed) / 1 (max)
7.1 cm x 22.4 cm x 16.6 cm
1 x Marvell ARMADA 3720 800 MHz (Dual-Core)
Storage Controller
SATA SATA 6Gb/s
Hard Drive
1 x 10 TB
10Mb LAN, 100Mb LAN, 1GbE
IP Cameras Supported
5
RAM
256 MB
Microsoft Windows 7, Windows 10, Apple MacOS X 10.11 or later
Host Connectivity
Gigabit Ethernet
10 TB
7.1 cm
22.4 cm
16.6 cm
Processor / Memory
Processors Installed
Number of Cores
Dual-Core
Max Supported Qty
1
RAM
256 MB DDR3
Storage Controller
SATA
Interface Type
SATA 6Gb/s
Hard Drive
HDD
1 x 10 TB
Network / Transport Protocol
TCP/IP, PPTP, L2TP, PPPoE, iSCSI, SMTP, FTP, POP3, IMAP
Remote Management Protocol
SNMP, Telnet, HTTP, HTTPS, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Network File System (NFS), FTP, Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
Firewall protection, VPN support, LDAP support, Access Control List (ACL) support, RADIUS support, FTP server, DNS server, VPN Server, file station
Encryption Algorithm
SSL, TLS
Security DVR
5
Expansion Bays
1 (total) / 0 (free) x internal - 2.5" / 3.5"
2 x USB 2.0 - Type A , 1 x Ethernet 1000Base-T - RJ-45
1 x network cable
Security lock slot (cable lock sold separately), built-in cooling fan
Security Slot Type
Kensington security slot
External power adapter
5 - 95%
