Synology DiskStation DS411slim 4-Bay 2.5" NAS
Quicklinx: 7B19WS00 Mfr#: DS411SLIM
Synology DiskStation DS411slim is designed to provide users with a compact yet feature laden solution for easy file sharing and backup. Snap-in 2.5" hard drives design brings low power consumption, quiet operation, reliability and easy disk replacement in a compact size. The operating system, Synology DiskStation Manager 3.0, delivers rich features for multimedia enjoyments, Internet sharing, worry-free data protection and energy-saving options.
  • Green, quiet, and reliable
    The Synology DS411slim is designed to work with 2.5" hard drives. The low power consumption characteristic of 2.5" hard drives will lower your electricity bill, as well as reduce your carbon footprint. In addition, 2.5" hard drives have reduced vibration, increased MTBF (mean time before failure), and shock tolerance. It not only extends hard drive's lifespan, but also provides better reliability. The smart fan design keeps the DS411slim's fan off under normal operations and spinning up at a very low speed only when needed, thus minimizing the noise level.
  • Flexible RAID management
    The Synology Hybrid RAID (SHR) automatically builds an optimal RAID volume with data protection based on the hard drives installed, eliminating the need to have hard drives of identical size, while still offering a manual setup option for advanced users.
  • Eco friendly
    Synology DiskStation is designed and developed perpetually with the concept of energy saving. Compared with average PC counterparts, Synology DiskStation consumes a relatively low amount of power and hibernates when not in use. This not only helps to save energy but also extends the lifespan of the hard disk.
Synology Disk Station DS411slim - NAS server - TAA Compliant
NAS server
Host Connectivity
Gigabit Ethernet
Max Supported Capacity
4 TB
0 (installed) / 4 (max)
10.5 cm x 14.2 cm x 12 cm
0.66 kg ()
Danish, Hungarian, Czech, Chinese (traditional), Chinese (simplified), Brazilian Portuguese, English, German, French, Italian, Norwegian, Portuguese, Polish, Swedish, Russian, Spanish, Dutch, Turkish, Japanese, Korean
1.6 GHz
Storage Controller
RAID Gigabit Ethernet SATA 3Gb/s RAID 0, 1, 5, 6, 10, JBOD, 5 hot spare
Hard Drive
SATA 3Gb/s
Network adapter - integrated - 10Mb LAN, 100Mb LAN, 1GbE
RAM
256 MB
Storage Operating System
Synology DiskStation Manager 2.3
Linux, Apple MacOS 9, Apple MacOS X, Microsoft Windows 98/2000/XP, Microsoft Windows Server 2003, Microsoft Windows Vista
TAA Compliant
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
0 GB
4 TB
10.5 cm
14.2 cm
12 cm
0.66 kg ()
Processor / Memory
Processors Installed
1.6 GHz
RAM
256 MB DDR3
Storage Controller
RAID - internal
Bus Type
Gigabit Ethernet
Interface Type
SATA 3Gb/s
Data Transfer Rate
300 MBps
Max Storage Devices Qty
4
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID 5 hot spare
Hard Drive
HDD - 2.5"
Interface Type
SATA 3Gb/s
Network / Transport Protocol
AppleTalk, PPPoE, iSCSI, FTP, DDNS
Remote Management Protocol
SNMP, Telnet, HTTP, HTTPS, SSH
Network Services Compatibility
DDNS, Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), HTTPS, Web-based Distributed Authoring and Versioning (WebDAV)
Print server, backup server, download client, ADS, SSH support, iTunes server, BitTorrent Client, e-mail server, DLNA Media Server
DLNA CERTIFIED
Expansion Bays
4 (total) / 4 (free) x internal - 2.5"
1 x eSATA 3Gb/s , 2 x USB 2.0 - Type A , 1 x Ethernet 1000Base-T - RJ-45
1 x network cable - 2 m
Built-in cooling fan
FCC Class B certified, RoHS, BSMI Class B, ROSTEST
TAA Compliant
External power adapter
16.8 Watt
Software Included
Drivers & Utilities, Synology Assistant, Synology Data Replicator 3, Synology Download Redirector, Printer Utility
TAA Compliant
5 °C
35 °C
5 - 95%
Sound Emission
21.1 dBA
Resources
The following resources are available for the Synology DiskStation DS411slim 4-Bay 2.5" NAS
