Synology 12TB HAS5300 3.5" SAS Hard Drive
Quicklinx: GF2DWS00 Mfr#: HAS5300-12T
Form Factor: 3.5
Type: Hard drive
Interface Type: [N/A]
Capacity: 12TB
Spin Speed (rpm): 7200rpm
£376.99 ex VAT
£452.38 inc VAT
The Synology HAS5300-12T 12TB SAS Hard Drive for NAS is designed to tackle demanding, high-volume workloads. Optimised specifically for Synology storage solutions, its design enables high sequential throughput, maximising the number of concurrent clients the system can sustain. The HAS5300-12T drive is engineered for maximum dependability, passing over 200,000 hours of validation.
Enterprise Reliability and Durability -
For demanding 24/7 environments, rated for 2.5 million hours MTTF and up to 550 TB per year workloads.
Persistent Write Cache Technology -
Minimises the chance of data corruption in the event of sudden power loss.
One-stop Update -
Get automatic firmware updates together through DSM updates, reducing the need for additional maintenance sessions.
For Synology, by Synology -
Stringent validation and up to 200,000 hours of tests ensures maximum reliability in Synology systems.
  • Enhanced reliability
    Boasting an impressive MTBF of 2,500,000 hours, this hard drive is designed for sustained reliability and durability, ensuring your data is secure over extensive use.
  • High-speed performance
    With a data transfer rate of 1.2 GBps and a 7200 rpm spindle speed, this hard drive delivers swift and efficient performance, making it ideal for enterprise environments.
  • Optimized for NAS
    NAS compatible and engineered to handle a workload of up to 550 TB per year, this hard drive is optimized for 24/7 operation in demanding storage environments.
Synology HAS5300 - hard drive - 12 TB - SAS 12Gb/s
Hard drive - internal
12 TB
3.5"
SAS 12Gb/s
Data Transfer Rate
1.2 GBps
Buffer Size
256 MB
Spindle Speed
7200 rpm
NAS compatible, Enterprise, workload up to 550 TB per year
101.85 mm x 147 mm x 26.1 mm
720 g
5-year warranty
Synology SA3200D, SA3400, SA3600; High Density HD6500; RackStation RS18016xs+, RS18017XS+; Unified Controller UC3200
12 TB
3.5"
SAS 12Gb/s
Buffer Size
256 MB
Bytes per Sector
512
101.85 mm
147 mm
26.1 mm
720 g
Performance
Drive Transfer Rate
1.2 GBps (external)
Internal Data Rate
242 MBps
Spindle Speed
7200 rpm
Reliability
MTBF
2,500,000 hours
Expansion & Connectivity
1 x SAS 12 Gb/s
Compatible Bay
3.5"
Power Consumption
4.36 Watt (idle) , 7.8 Watt (random read/write)
Limited warranty - 5 years
Synology SA3200D, SA3400, SA3600 , Synology High Density HD6500 , Synology RackStation RS18016xs+, RS18017XS+ , Synology Unified Controller UC3200
Form Factor: 3.5
Type: Hard drive
Capacity: 12TB
Brand: Synology
