StarTech.com Wireless Infrared IR Remote Control Extender - 330ft (100m)
Quicklinx: 8ZCKWS00 Mfr#: IREXT2
The IREXT2 Wireless IR Extender Kit lets you extend an Infrared signal from a remote control by up to 330ft (100m).
Using a radio frequency that can operate through walls, doors, and around corners, the remote control extender lets you control your A/V devices from greater distances or even from another room. This adds configuration versatility for multi-room or outdoor applications, without having to move within range of your remote controlled device.
Extend IR remote control signals wirelessly by up to 330 feet (100 meters). The remote control extender is comprised of two units - one local IR remote extender, which accepts the incoming IR signal from the remote control and wirelessly transmits it to the second IR remote control Receiver unit positioned near the controlled device.
StarTech.com Wireless IR Remote Control Extender - 330 ft / 100m - IR to RF - Infrared Repeater - IR Extender for Cable Box - IR Repeater Kit (IREXT2) - extender for remote control
Extender
Intended For
Remote control
Wireless Interface
Infrared
Package Content
IR receiver, IR transmitter, 2 AC power adapters
Product Material
Plastic
6.7 cm x 10.3 cm x 3.53 cm
266.7 g
Grey
P/N: SVA12M2NEUA, SVA12M5NA
Extender
Intended For
Remote control
Wireless Interface
Infrared (IrDA)
Max Operating Distance
100 m
Package Content
Product Material
Plastic
6.7 cm
10.3 cm
3.53 cm
266.7 g
Grey
2 years
