Connect your USB-C peripherals to a USB-A laptop, hub, or charger
Connect a USB-C cable to a USB-A laptop or convert a USB-A port to Type-C using this compact USB-A Male to USB-C Female adapter. The compact, streamlined design ensures straightforward connectivity without blocking adjacent ports, and supports USB 10Gbps performance for fast data transfer.
Wide Compatibility
The USB-A to USB-C adapter is universally compatible with any operating system. Simple plug-and-play setup enables instant deployment. The adapter supports USB 10Gbps and facilitates up to 5V/900mA output from a powered USB-A connection such as a wall charger. This enables consistent charging to a USB-C device from a USB-A source. Please note that USB-C video and Power Delivery are not supported.
Durable Construction
The USB-A to USB-C adapter features a durable PVC housing that protects against everyday wear. Nickel-plated connectors ensure a flush fit to help reduce signal loss, providing reliable performance for frequent use.
