StarTech.com Wi-Fi Wireless Range Extender – 300 Mbps 802.11 b/g/n Access Point / Signal Booster
Quicklinx: 8BM8WS00 Mfr#: WFREPEAT300N
  • IEEE 802.11n
Create or extend the range of a Wireless-N (300Mbps) WiFi network. The WFREPEAT300N Wireless-N Extender offers two selectable operating modes that enable it to be used as an Access Point or repeater, for either extending the range of existing wireless networks or adding wireless capabilities to a non-wireless network. Using a wall plug design, this allows for convenient or hidden placement anywhere there is an available AC outlet.
Used as a Wireless-N repeater, the WFREPEAT300N can expand the effective range of any 802.11n WiFi network, delivering up to 300Mbps of data bandwidth, by boosting the WiFi signal to help eliminate dead spots and provide a stronger signal in areas with obstructions which would typically reduce the wireless range. The WiFi range extender is also backward compatible with 802.11b/802.11g networks, for versatile network expansion with wireless routers that use older standards.
When used as a wireless access point (AP), the WFREPEAT300N can add wireless-N capability to any non-wireless router, ensuring maximum convenience and network scalability.
To provide maximum privacy and help prevent network intrusions, the Wireless-N Extender/Repeater offers a built-in firewall with IP, MAC Address and URL filtering, and supports common WiFi security protocols (WEP/WPA/WPA2).
StarTech.com Wi-Fi Wireless Range Extender - 300 Mbps 802.11 b/g/n Access Point / Repeater / Signal Booster - Wi-Fi range extender - Wi-Fi
External
Realtek Semiconductor RTL8196C
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
6 cm x 10 cm x 5 cm
120 g
6 cm
10 cm
5 cm
120 g
Enclosure Colour
White
Processor / Memory / Storage
Processors Installed
External
Wireless
Data Transfer Rate
300 Mbps
Line Coding Format
DBPSK, DQPSK, CCK, 64 QAM, 16 QAM, OFDM
Frequency Band
2.4 GHz
Status Indicators
Power, wireless, link/activity
Encryption Algorithm
AES, TKIP, WPA, WPA2
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
1 x 100Base-TX - RJ-45
1 x network cable
UL, FCC, RoHS
External power adapter
10 - 90%
8BM8 StarTech.com USB 150Mbps Mini Wireless N Network Adapter - 802.11n/g 1T1R In Stock £12.77
