StarTech.com White Apple 30-pin Dock Connector to Micro USB Adapter with Stepped Connector
Quicklinx: 9KZXWS00 Mfr#: USBUBADCADPW
Colours:
Charge or Sync your iPhone, iPod, or iPad using a Micro USB cable. The USBUBADCADPW Apple 30-pin Dock Connector to Micro USB Adapter is colored to suit white iPhone, iPod, iPad mobile devices and provides a reliable solution for charging and syncing your Apple mobile digital devices using a Micro USB cable.
The uniquely constructed adapter features a stepped Apple Dock Connector (male), which saves the hassle of removing the protective case or cover from your device each time you charge or sync.
Plus, this compact adapter is portable enough for carrying as a tablet or laptop accessory while reducing the number of cables you need to carry around with you in order to charge all of your mobile devices.
This durable 30-pin to Micro USB adapter is Apple MFi certified.
StarTech.com White Apple 30-pin Dock to Micro USB Adapter iPhone iPod iPad - charging / data adapter
Cable
Charging / data adapter
White
Connector
Apple Dock - male
Connector (Second End)
Micro-USB Type B - female
Apple iPod (4G, 5G); iPod classic; iPod mini
Cable Type
Plated Connector
Nickel
White
Connector
Apple Dock connector - male
5 pin Micro-USB Type B - female
RoHS
Limited warranty - lifetime
Apple iPod (4G, 5G) , Apple iPod classic , Apple iPod mini
