StarTech.com Wall Mounted Sit Stand Desk
Quicklinx: DBT5WS00 Mfr#: WALLSTS1
£258.08 ex VAT
£309.69 inc VAT
Easily convert your workstation into a standing desk for greater comfort and productivity. This wall-mounted sit-stand desk is perfect for areas that don't have enough space for a traditional sit-stand desk. Its compact, wall-mounted design combines a single-monitor arm and a keyboard tray, with easy height adjustments that let you alternate between sitting and standing without disrupting your workflow.
Adjust your working position in one smooth motion. Simply lift the work surface up to 17.2" (436 mm), to elevate your monitor, keyboard and mouse. The monitor mount has a separate height adjustment of up to 4.9" (124 mm) along the column.
This sit-stand monitor arm supports one monitor up to 24" (with weight capacity of 17.6 lb./8 kg). Adjust your monitor for ideal viewing with -5° to 35° tilt, or rotate your monitors up to 360° for portrait or landscape orientation.
The sit-stand desk folds back to the wall, and keyboard tray folds up to 90°, saving space when not in use. You can move the swing arm left or right (from -90° to 90°) and lower or raise the arm (from -30° to 65°) to make maximum use of your space.
The monitor arm offers plenty of work space with a large keyboard tray (17.68 x 8.15"/ 449 x 207 mm) and a slide-out tray (8.5 x 8.4" / 217 x 213 mm) that holds your mouse, on the left or right.
StarTech.com Wall Mounted Sit Stand Desk - Single Monitor - Adjustable Standing Desk Converter - Height Adjustable Desk - Desk Riser (WALLSTS1) - mounting kit
Mounting kit
Mounting Components
Wall plate, column, keyboard tray, monitor arm
66.8 cm x 95.6 cm x 92.6 cm
Tilt
-5° to 35°
Pan
-90° to 90°
Rotation
360°
Adjustments
9.3 kg
Recommended Use
Monitor
Recommended Display Size
24"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
8 kg
Material
Plastic, aluminium, steel
Package Content
4 x concrete anchors, 4 x M6x12 screws, hex key (5mm), hex key (2.5mm), hex key (6mm), wall plate, 2 x washers, adhesive strip, socket driver, M8x20 screw, 3 x M6x10 screws, 4 x M4x10 screws, M6x8 screw, VESA monitor mount, 4 x mounting screws
66.8 cm
95.6 cm
92.6 cm
9.3 kg
Material
Package Content
AV Furniture
Mounting kit
Mounting Components
Recommended Use
Monitor
Cable Management
Integrated cable management
24"
Tilt
-5° to 35°
Pan
-90° to 90°
Rotation
360°
Adjustments
Max Load Weight
8 kg
Dimensions & Weight Details
Dimensions
Keyboard tray - width: 44.9 cm, depth: 20.7 cm
StarTech.com Wall Mounted Sit Stand Desk Bundle deal on StarTech.com Wall Mounted Sit Stand Desk
£357.25
DBT5 StarTech.com Sit Stand Monitor Arm In Stock £213.47
DBT5 StarTech.com Sit Stand Dual Monitor Arm In Stock £279.49
DBT5 StarTech.com Wall Mounted Sit Stand Desk In Stock £258.08
DBT5 StarTech.com Dual Sit Stand Desk/Wall Mount In Stock £283.91
Price Range Ex VAT: 150 - 300
