Increase your productivity, with a workstation that fits the way you work. Designed for a wide range of motion, this wall-mounted computer workstation is easily adjustable with independent arms for your monitor and keyboard.
Move the wall-mounted sit-stand desk into position to work. Then push it back against the wall when not in use, folding the arms close to the wall. It's perfect for use in hospitals, clinics, warehouses, and other space-limited areas.
Extend the articulating monitor arm up to 25.6" (65 cm) from the wall. For ideal positioning, tilt or swivel your monitor, or rotate 360 degrees. The sit-stand workstation supports a VESA mount (75x75, 100x100) monitor up to 30", with a maximum weight of 19.8 lb. (9 kg).
This wall-mounted height-adjustable desk enables a wide range of users to work in comfort. Adjust the height of both arms along the pole up to 17.5" (44.5 cm), plus the spring monitor arm has a height adjustment range of 10.6" (27 cm).
Place your keyboard where you need it, with an independent keyboard tray that extends up to 30.9" (78.4 cm) from the wall. Tilt the keyboard back to make sure your wrists are in a neutral position while typing. Place your mouse in the holder when not in use.
The modular design, with quick slide-and-click connections, makes installation easy and saves time when setting up multiple units.
- StarTech.com Wall Mount Workstation - Foldable Ergonomic Standing Desk - Height Adjustable 34" VESA Monitor Arm/Padded Keyboard/Mouse Tray - mounting kit
- Product Type
- Mounting kit - wall-mountable
- Mounting Components
- Pole, mouse holder, wrist rest, spring arm, wall mount bracket, keyboard tray, monitor mount, wall mount bracket with lock plate, swivel arm with logo, 2 x swivel arms, mouse tray, mouse tray fixed plate, EVA mouse pad
- 68.3 cm x 74.2 cm x 123 cm
- Tilt
- -15° to 90°
- Pan
- -120° to 120°
- Rotation
- 360°
- Adjustments
- 11.2 kg
- Recommended Use
- LCD display / keyboard / mouse
- Recommended Display Size
- 13"-30"
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm
- Max Load Weight
- 11.5 kg
- Material
- Plastic, aluminium, steel
- Silver
- 2-year warranty
- 68.3 cm
- 74.2 cm
- 123 cm
- 11.2 kg
- Material
- Silver
AV Furniture
- Mounting kit
- Recommended Use
- Placing / Mounting
- Wall-mountable
- Cable Management
- Integrated cable management
- 13"-30"
- Tilt
- -15° to 90°
- Pan
- -120° to 120°
- Rotation
- 360°
- Adjustments
- Max Load Weight
- 11.5 kg
- TAA Compliant
Dimensions & Weight Details
- Dimensions
- Keyboard tray - width: 68.3 cm, depth: 25.8 cm
- Shipping Dimensions (WxDxH) / Weight
- 95 cm x 14 cm x 59 cm / 11.4 kg
- Limited warranty - 2 years
StarTech.com Anti-Fatigue Mat - 20" x 30" | In Stock | £58.61 |
StarTech.com Wall Mounted Sit Stand Desk | In Stock | £297.98 |
StarTech.com Dual Sit Stand Desk/Wall Mount | In Stock | £328.33 |
StarTech.com Anti-Fatigue Mat - Large | In Stock | £66.28 |
StarTech.com Wall Mounted Workstation - Extendable Dual Monitor Arm | In Stock | £538.13 |
StarTech.com Wall Mounted Computer Workstation - Extendable Monitor Arm | In Stock | £332.99 |
