Convert and scale your legacy VGA source into an HDMI video signal, for compatibility with newer displays. This VGA to HDMI converter and scaler lets you connect your analog VGA video signal to a digital HDMI display. It features a built-in video scaler that adjusts the output signal to suit virtually any HDMI display. It scales the signal to your choice of resolutions, up to 1080p.
The converter and scaler features 3.5mm and optical audio inputs, which let you combine audio into the HDMI output. The scaler creates a digital signal at high resolutions that's perfect for updating legacy VGA video equipment to work with newer HDMI televisions or projectors.
New HDMI displays are phasing out support for lower resolution video signals such as 480i, 480p, and 720p. Without support for these common VGA resolutions, you may not be able to use a standard adapter to connect your legacy video output to your new display.
This converter lets you continue using your current VGA source equipment by scaling your video signal to a resolution that's compatible with your new HDMI display. Scaling your source enables you to upgrade to a sleek new HDMI display while keeping your tried-and-true source material on display at trade shows and storefronts.
Upgrading every component in your A/V setup can be costly and time consuming. Retaining your source can save you the cost and hassle of buying and configuring new equipment. With the VGA to HDMI converter, you can bridge the gap between old and new technologies by converting your dependable VGA source to high-resolution HDMI.
This converter features automatic resolution detection that minimizes your setup time by avoiding tedious programming. Plus, it features an intuitive on-screen menu that lets you customize the parameters of your input to quickly select and compare different output options, ensuring you get the best video solution possible in a very short time period.
This converter does not output digitally-encrypted content. This converter is the direct replacement for VGA2HDMIPRO.
- StarTech.com VGA to HDMI Converter - Analog VGA to digital HDMI Scaler with Audio - 1920x1200 (VGA2HDPRO2) - video converter - black
- Video converter
- Max Resolution
- 1920 x 1080
- 1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x audio line-in - mini-phone stereo 3.5 mm / mini-TOSLINK , 1 x audio line-in - TOSLINK , 1 x HDMI input - 19 pin HDMI Type A , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x audio line-out - TOSLINK
- Enclosure Colour
- Black
- 2-year warranty
- Designed For
- P/N: SVA5M3NEUA
- Video converter
- Max Resolution
- 1920 x 1080
- 1 x VGA input - 15 pin HD D-Sub (HD-15) - female , 1 x audio line-in - mini-phone stereo 3.5 mm / mini-TOSLINK - female , 1 x audio line-in - TOSLINK - female , 1 x HDMI input - 19 pin HDMI Type A - female , 1 x audio line-out - mini-phone stereo 3.5 mm - female , 1 x audio line-out - TOSLINK - female
- LED indicator, built-in scaler
- Included Accessories
- Power adapter
- Cables Included
- 1 x VGA cable - 1.2 m , 1 x mini-phone 3.5 mm to RCA cable - 1.8 m
- FCC, RoHS
- Enclosure Colour
- Black
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 20 - 90% (non-condensing)
- Designed For
- P/N: SVA5M3NEUA
StarTech.com 6 ft 3.5mm Stereo Extension Audio Cable - M/F | In Stock | £4.98 |
StarTech.com High Resolution VGA to Composite (RCA) or S-Video Converter - PC to TV | In Stock | £87.60 |
StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £4.99 |
StarTech.com 15 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £5.83 |
StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £3.79 |
StarTech.com 3 ft Stereo Audio Cable - 3.5mm Male to 2x RCA Male | In Stock | £4.68 |
StarTech.com 15 ft Thin Toslink Digital Optical SPDIF Audio Cable | In Stock | £5.32 |
StarTech.com VGA to HDMI Adapter with USB Audio & Power- Portable VGA to HDMI Converter 1080p | In Stock | £37.67 |
StarTech.com Conference Table Connectivity Box – HDMI / VGA / Mini DisplayPort to HDMI Output | In Stock | £191.07 |
StarTech.com DC Power Adapter - 5V, 3A | In Stock | £11.71 |
StarTech.com DisplayPort VGA HDMI Converter Switch | In Stock | £243.98 |
StarTech.com 2 m (6.6 ft.) VGA to HDMI Adapter Cable with USB Audio | In Stock | £31.06 |
