The THINTOS15 15 ft Toslink Optical Digital Audio Cable provides clean, accurate sound, with no distortion or signal interference.
The thin construction of this Optical SPDIF cable is perfect for installations in tight spaces. The cable features a polished lens, which helps ensure a reliable signal and high-level digital sound quality.
This 15ft Optical Audio Cable is constructed for maximum durability, for dependable, long-lasting connections.
Durable construction
The cable features a PVC jacket that provides added protection against wear and tear, ensuring long-lasting use. -
High-quality connectors
Gold-plated male TOSLINK connectors enhance conductivity and resist corrosion, providing a reliable connection. -
Optical audio transmission
Utilizing fiber optic technology, this cable delivers high-fidelity audio signals for an immersive listening experience. -
Long cable length
At 15 ft, this cable allows for versatile placement of your audio devices, accommodating various layouts and setups. -
RoHS compliant
This product meets RoHS standards, ensuring it is free from hazardous substances for safer usage.
- StarTech.com 15 ft Thin Toslink Digital Optical SPDIF Audio Cable - 15ft / 15 Feet Optical Audio Cable (THINTOS15) - digital audio cable (optical) - SPDIF - 4.6 m
- Cable
- Digital audio cable (optical) - SPDIF
- Technology
- Fibre optic
- Length
- 4.6 m
- Black
- Connector
- TOSLINK - male
- Connector (Second End)
- TOSLINK - male
- Limited lifetime warranty
- Designed For
- P/N: BT2A, FLATPNLCEIL, FLATPNLWALL, FPCEILPTBLP, FPCEILPTBSP, FPWARTB1M, FPWARTB2, FPWFXBAT, FPWTLTBAT, HD202A, PEXSOUND7CH, STNDMTV100, STNDMTV70, VGA2HDPRO2, WIFI2HDVGA
- Cable Type
- Interface Supported
- SPDIF
- Technology
- Fibre optic
- Jacket Material
- PVC
- Length
- 4.6 m
- Plated Connector
- Gold
- Black
- Connector
- TOSLINK - male
- TOSLINK - male
- RoHS
- Limited warranty - lifetime
- Designed For
