StarTech.com VGA DP & HDMI Over CAT5 Switch
Quicklinx: CJS8WS00 Mfr#: STDHVHDBT
£457.71 ex VAT
£549.25 inc VAT
Connect your laptop to a remote display over standard CAT5 or CAT6 cabling, and easily swap between HDMI, DP or VGA video sources. This multi-input video extender kit uses HDBaseT technology to extend your video signals up to 230 feet (70 meters) over a single CAT5e or CAT6 cable. It features a built-in video switch that enables you to choose which video source is outputted from four independent video sources (2 x HDMI, 1 x VGA and 1 x DisplayPort).The video extender supports Ultra HD 4K and Full HD 1080p video resolutions, with support for the accompanying digital 7.1 audio.
This HDBaseT extender features a built-in converter switch, so you can connect two HDMI sources as well as a VGA and a DisplayPort video source to the same remote HDMI display, without having to use additional adapters or scalers or a separate video switch.
With support for multiple video sources and HDBaseT, this extender is the perfect solution for adding a large display to your boardroom or classroom, enabling BYOD laptops with HDMI, DisplayPort or VGA outputs to share their display with the room.
The extender switch ensures hassle-free operation, with two different auto-switching modes: auto-detect switching, which detects and selects a newly connected device, or priority selection, which lets you choose which port should be activated by default for automatic switching.
The multi-input video extender kit is perfect for digital signage applications, where an automatic switch can replace a failed source with a secondary input to avoid embarrassing video outages. Plus, the combined built-in HDBaseT functionality means you can connect a remote digital signage display with one kit that reduces failure points.
The kit extends your video signal over a single cable, unlike some video extender systems that require two cables and only offer minimal audio support. Extending your video with one cable reduces potential failure points and also lowers your cabling costs.
Using standard CAT5e, CAT6 or CAT7 cables, the HDBaseT extender works with existing Ethernet infrastructure that's already built into large commercial buildings such as shopping centers, stadiums, schools, and hospitals, making it the perfect solution for deploying digital signage.
With high-quality HDMI cables beginning signal degradation at 30 feet, it can be difficult to maintain the brilliance of 4K video even at shorter distances. But with HDBaseT, you'll be amazed at how your Ultra HD picture - four times the resolution of high-definition 1080p, is just as brilliant even at distances up to 130 feet from your video source.
Even if you're not running 4K, HDBaseT supports High-Definition 1080p and lower resolutions at even greater distances, up to 230 feet from your source, giving you peace of mind knowing that this extender will comfortably work with any HDMI video source and display.
HDBaseT is a zero-latency connectivity standard that's revolutionizing HDMI distribution. HDBaseT uses an advanced method of modulation that enables you to distribute uncompressed HDMI audio and video, along with additional signals, over a single Ethernet cable. Offering greater versatility than traditional HDMI extenders and longer distances than HDMI cables alone, HDBaseT is the clear choice for every integrator and system designer, because it can do so much, with just a single cable.
StarTech.com Multi-Input HDBaseT Extender with Built-in Switch - DisplayPort VGA and HDMI Over CAT5e or CAT6 - Up to 4K - up to 230 ft (STDHVHDBT) - video/audio extender - HDMI
Video/audio extender
Rack-mountable
HDMI
Transmission Medium
CAT 5e/6
Max Transfer Distance
70 m
AC 120/230 V / DC 12 V
Rack-mountable
Wired
HDMI
70 m
Status Indicators
Status
4K resolution support, 7.1 channel audio support, Dolby TrueHD support, DTS-HD Master Audio support, 1080p resolution support
1 x HDBaseT (input) - RJ-45 female , 1 x HDMI (output) - 19 pin HDMI Type A female , 2 x HDMI (input) - 19 pin HDMI Type A female , 1 x DisplayPort (input) female , 1 x VGA (input) - DB-15 female , 2 x IrDA female , 1 x (output) - RJ-45 female
Remote control, 2 mounting brackets, foot pad set, HDBaseT receiver
1 x network cable , 1 x RJ-11 phone cable
External power adapter
0 - 80% (non-condensing)
CJS8 StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £7.92
CJS8 StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £13.58
CJS8 StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £5.37
CJS8 StarTech.com 15 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £5.56
CJS8 StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £3.97
CJS8 StarTech.com 12V DC 1.5A Universal Power Adapter In Stock £15.73
CJS8 StarTech.com 3 ft Stereo Audio Cable - 3.5mm Male to 2x RCA Male In Stock £4.94
CJS8 StarTech.com HDMI Over Single Cat 5e / 6 Extender with Power Over Cable - 230 ft (70m) In Stock £187.84
CJS8 StarTech.com HDMI Over CAT5e / CAT6 Extender with Power Over Cable - 330 ft (100m) In Stock £318.01
CJS8 StarTech.com Lockable Floor Stand for iPad In Stock £137.81
CJS8 StarTech.com 6 ft DisplayPort Cable with Latches - M/M In Stock £13.78
CJS8 StarTech.com 4K HDMI Extender, 4K 60Hz HDR In Stock £165.60
