StarTech.com 3 ft Stereo Audio Cable - 3.5mm Male to 2x RCA Male
Quicklinx: 7VXKWS00 Mfr#: MU3MMRCA
Length: 92cm
£4.91 ex VAT
£5.89 inc VAT
Connect your Computer or Audio Player to an RCA Audio Device. The MU3MMRCA 3-foot 3.5mm audio to RCA audio cable delivers a cost-effective solution for connecting a portable audio device such as an iPod (or other MP3 player) to a stereo receiver/amplifier.
This versatile cable can also be used to connect a computer sound card to an audio device that accepts RCA audio input.
The cable features a 3.5mm audio (male) connector, which splits off into two RCA (phono) audio male connectors, providing high quality stereo sound.
Designed to provide high quality audio as well as a durable and dependable connection.
  • Versatile connectivity
    This audio cable features a 3.5 mm male connector on one end and dual RCA male connectors on the other, making it suitable for a range of audio devices.
  • Color-coded connectors
    The cable is equipped with color-coded connectors, simplifying the process of connecting audio equipment and reducing installation time.
  • Durable construction
    With a PVC jacket and 28 AWG design, this cable is built to withstand wear and tear while providing reliable audio quality.
  • Safe and compliant
    The product complies with RoHS standards, ensuring it is safe for both users and the environment.
StarTech.com 3 ft Stereo Audio Cable - 3.5mm Male to 2x RCA Male - heaDPhone jack to RCA - Mini jack to RCA - 3.5mm to RCA (MU3MMRCA) - audio cable - 92 cm
Cable
Audio cable
American Wire Gauge (AWG)
28
Length
92 cm
Connector
Mini-phone stereo 3.5 mm - male
Connector (Second End)
RCA x 2 - male
Colour-coded connectors
P/N: DP2VGAA, DP2VGAAMM2M, DP2VGAAMM3M, HD202A, HD2A, HD2VGAA2, HD2VGAMICRA, IPUSB2VGA2, ST121HDBT5, ST121HDBTRP, ST121HDBTSC, ST121HDBTU, ST12MHDLAN4K, ST12MHDLAN4R, ST12MHDLNHK, ST12MHDLNHR, ST222HDBT, STDHVHDBT, VGA2HDPRO2, VID2HDCON2, VS221HD2VGA, VS221VGA2HD, WIFI2HD2, WIFI2HDMC, WIFI2HDVGA
Cable Type
Audio cable
28
Jacket Material
PVC
Length
92 cm
Connector
RCA x 2 - male
RoHS
Limited warranty - lifetime
P/N: COMPUTPEXTA, CPNT2VGAA, CPNTA2HDMI, DP2VGAA, DP2VGAAMM2M, DP2VGAAMM3M, DVI2HDMIA, HD202A, HD2A, HD2VGAA2, HD2VGAMICRA, HDMI2VGA, IPUSB2VGA2, ST121HDBT5, ST121HDBTRP, ST121HDBTSC, ST121HDBTU, ST122DVIA, ST122HDMI2, ST122LEA, ST122PROA, ST123HDA, ST124DVIA, ST124HDMI2, ST124UTPEA, ST128HDMI2, ST12MHDLAN4K, ST12MHDLAN4R, ST12MHDLNHK, ST12MHDLNHR, ST222HDBT, ST222MXA, ST424MX, STDHVHDBT, STUTPEALR, STUTPWALLA, VGA2HD2, VGA2HDPRO2, VID2HDCON, VID2HDCON2, VS221HD2VGA, VS221VGA2HD, VS410RVGAA, VS420RDVIA, VS721MULTI, WIFI2HD2, WIFI2HDMC, WIFI2HDVGA
7VXK StarTech.com 6in Stereo Audio Cable - 3.5mm Male to 2x RCA Female In Stock £4.20
Length: 92cm
