StarTech.com USB3.1 Dual External Enclosure
Quicklinx: BMPVWS00 Mfr#: S252BU313R
Turn two 2.5" SATA SSDs or HDDs into high-performance storage with RAID - for USB-C and USB-A enabled devices. Compact in size but big on performance, this dual-bay enclosure provides powerful external data storage, with ultra-fast data transfer speeds and configurable RAID modes. It's ideal for small business and home office applications, or top-performing workstations for graphic designers, engineers and other business professionals.
Create a high-capacity, external data storage solution with support for two 2.5" SSDs/HDDs in a wide range of sizes from 5 to 12.5mm, with capacities up to and beyond 2TB. This aluminum enclosure delivers fast file transfer rates with USB 3.1 Gen 2 performance, supports SATA I, II and III and is enhanced with UASP to maximize the performance and speed of your SATA III drives. It even has a fan, with built-in speed control, to keep things running smoothly.
USB 3.1 Gen 2 gives you greater bandwidth and speed, supporting transfer rates of up to 10Gbps - twice the speed of USB 3.0 (USB 3.1 Gen 1) technology. It lets you leverage the high performance of the latest SSDs and hard drives while alleviating bottlenecks in your data transfers.
The dual-bay drive enclosure comes with two USB cables for flexible use with the latest laptops and tablets equipped with a USB-C port, as well as legacy devices. It includes both USB-C to Micro B and USB-A to Micro B cables. The 2-bay enclosure is also compatible with a Thunderbolt 3 USB-C port.
Through RAID 0 support, the dual-bay enclosure lets you maximize the performance of your SATA III SSDs to achieve greater file transfer speeds. The dual-bay enclosure also supports RAID 1, Big (Spanning or Concatenation) and JBOD. With multiple RAID options, you can gain increased storage size, performance, or redundancy.
The enclosure is OS independent, requiring no additional software or drivers.
StarTech.com USB 3.1 (10Gbps) External Enclosure for 2.5" SATA Hard Drives - RAID - 2-Bay USB Type-C Hard Drive Enclosure (S252BU313R) - storage enclosure - SATA 6Gb/s - USB 3.1 (Gen 2)
Storage enclosure - external
Bus Type
USB 3.1 (Gen 2)
Expansion Bays
2 x internal - 2.5"
Hard Drive Form Factor Compatibility
2.5"
Cooling fan
SATA 6Gb/s
Data Transfer Rate
10 GBps
Supported Devices
Hard drive, solid state drive
Max Storage Devices Qty
2
RAID Level
RAID 0, RAID 1, JBOD, BIG
Product Material
Aluminium
AC 120/230 V
8.1 cm x 14.2 cm x 6 cm
P/N: PEXUSB311AC2, PEXUSB312A1C1H, PEXUSB312A2C2V, PEXUSB312C2, PEXUSB312EIC, TBLT3MM1MA, TBLT3MM2M, TBLT3MM2MA
2.5"
Hard Drive Maximum Height
12.5 mm
Host Bus
USB 3.1 (Gen 2)
Product Material
Aluminium
Cooling fan
Storage Controller
SATA 6Gb/s
Data Transfer Rate
10 GBps
Supported Devices
2
RAID Level
ASMedia ASM1352R
Bays
2 x internal - 2.5"
2 x SATA 6Gb/s - SATA combo
1 x USB 3.1 (Gen 2) - 10 pin Micro-USB Type B
Key
1 x USB cable - external
Key lock, rubber feet, UASP transfer protocol, 3 LED indicators
FCC, RoHS
Power adapter
AC 120/230 V
8.1 cm
14.2 cm
6 cm
5 °C
35 °C
20 - 80%
BMPV StarTech.com 0.5m (1.5ft) Black SuperSpeed USB 3.0 Cable A to Micro B - M/M In Stock £8.46
BMPV StarTech.com USB 3.1 Enclosure for 2.5" SSD In Stock £26.43
BMPV StarTech.com USB 3.1 Gen 2 Single-bay Dock In Stock £53.68
BMPV StarTech.com USB 3.1 Gen 2 Dual-bay Dock In Stock £82.78
BMPV StarTech.com Dual M.2 Enclosure - RAID In Stock £42.94
BMPV StarTech.com StarTech.com 2-Port 10Gbps USB-A/USB-C PCIe Card -USB 3.1 In Stock £38.05
