The USB2VGAE2 USB to VGA external video adapter is the perfect multi-monitor VGA solution for office applications and Internet browsing.
The USB video adapter features a small form factor and enables a USB 2.0 port to be used with a VGA port. A cost-saving multi-monitor or dual display option that can be used as an external graphics card for either laptop or desktop applications.
The USB video adapter can be used with up to four additional (five total) USB2VGAE2 USB video adapters, creating multiple VGA connections that can be used to further extend or mirror the desktop shown on the existing display - all without having to open the computer case to add extra video cards.
- StarTech.com USB to VGA Adapter - 1440x900 - adapter - VGA / USB - TAA Compliant - 7.5 cm
- Cable
- Adapter - VGA / USB
- TAA Compliant
- Max Output Resolution
- 1600 x 1200
- Length
- 7.5 cm
- Grey
- Connector
- USB - male (input)
- Connector (Second End)
- HD-15 (VGA) - female (output)
- USB / USB 2.0
- 2-year warranty
- Designed For
- P/N: MXT101MM
- Cable Type
- Adapter
- Interface Supported
- VGA / USB
- Jacket Material
- Plastic
- USB / USB 2.0
- Length
- 7.5 cm
- Grey
Adapters & Converters
- 1600 x 1200
- OS Required
- Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10
- Connector
- 4 pin USB Type A - male (input)
- 15 pin HD D-Sub (HD-15) - female (output)
- FCC, RoHS, WEEE, REACH, RCM
- TAA Compliant
- 4.2 cm
- 5 cm
- 80 g
- Shipping Width
- 14.8 cm
- Shipping Depth
- 21 cm
- Shipping Height
- 4 cm
- Shipping Weight
- 235 g
- Limited warranty - 2 years
- Designed For
- P/N: MXT101MM
StarTech.com USB to VGA Multi Monitor External Video Adapter | In Stock | £15.36 |
StarTech.com USB to VGA External Video Card Multi Monitor Adapter – 1920x1200 | In Stock | £12.04 |
StarTech.com Slim USB 3.0 to VGA External Video Card Multi Monitor Adapter – 1920x1200 / 1080p | In Stock | £18.89 |
StarTech.com USB 3.0 VGA Video Adapter | In Stock | £17.28 |
StarTech.com USB 3.0 to HDMI VGA Adapter - 4K 30 - External Video & Graph | In Stock | £60.54 |
