USB 3.0 External Video & Graphics Card 2-in-1 Multiport Adapter Mac & Windows . This USB 3.0 to HDMI VGA adapter offers a portable solution for connecting an HDMI and VGA display to your USB-A laptop or desktop computer. The multiport video adapter lets you mirror or extend content on two additional monitors simultaneously (1 x HDMI and 1 x VGA), creating a dual-screen workstation.
Enhance Your Productivity
Functioning as an external graphics card, this multi-display adapter provides a convenient way to add multi-monitor capability to a USB 3.0 desktop or laptop computer.
Leveraging the USB 3.0 interface, the adapter delivers high-definition content to your HDMI and VGA displays. The adapter can be used to mirror your primary desktop, or to extend your desktop to double your workspace and increase your productivity.
Two-in-One Video Connectivity with Travel in Mind
Avoid the hassle of carrying different adapters. This USB 3.0 video converter provides both HDMI and VGA outputs, you can conveniently connect your laptop to any HDMI and VGA-equipped display or projector, using this multiport adapter.
The lightweight dongle also features a small footprint, making it the perfect accessory for professionals on-the-go.
Astonishing 4K Picture Quality
The HDMI output on this USB 3.0 video adapter supports UHD resolutions up to 4K 30Hz, while the VGA output supports HD resolutions up to 1920 x 1080, ensuring you won't have to sacrifice picture quality.
USB32HDVGA is backed by a StarTech.com 3-year warranty and free lifetime technical support.
Functioning as an external graphics card, this multi-display adapter provides a convenient way to add multi-monitor capability to a USB 3.0 desktop or laptop computer. Leveraging the USB 3.0 interface, the adapter delivers high-definition content to your HDMI and VGA displays. The adapter can be used to mirror your primary desktop, or to extend your desktop to double your workspace and increase your productivity. -
Avoid the hassle of carrying different adapters. This USB 3.0 video converter provides both HDMI and VGA outputs, you can conveniently connect your laptop to any HDMI and VGA-equipped display or projector, using this multiport adapter. The lightweight dongle also features a small footprint, making it the perfect accessory for professionals on-the-go. -
The HDMI output on this USB 3.0 video adapter supports UHD resolutions up to 4K 30Hz, while the VGA output supports HD resolutions up to 1920 x 1080, ensuring you won't have to sacrifice picture quality. USB32HDVGA is backed by a StarTech.com 3-year warranty and free lifetime technical support.
- StarTech.com USB 3.0 to HDMI and VGA Adapter, 4K/1080p USB Type-A Dual Monitor Multiport Adapter Converter, External Video Graphics Card for Multiple Screens, Multi Display USB Adapter - USB 3.0 to HDMI VGA (USB32HDVGA) - adapter - HDMI / VGA / audio
- Cable
- Adapter - HDMI / VGA / audio
- Max Output Resolution
- 3840 x 2160 - 30 Hz
- Black, silver
- Connectors
- USB Type A - male (input)
- Connectors (Second End)
- HDMI - female (output) , HD-15 (VGA) - female (output)
- USB 3.0
- 3-year warranty
- Cable Type
- Adapter
- Interface Supported
- USB 3.0
- Black, silver
Adapters & Converters
- 3840 x 2160
- Refresh Rate
- 30 Hz
- OS Required
- Apple OS X 10.10 Yosemite, Apple OS X 10.11 El Capitan, Apple macOS Sierra 10.12, Apple macOS High Sierra 10.13, Apple macOS Mojave 10.14, Apple macOS Catalina 10.15, Apple macOS Big Sur 11.0, Apple macOS Monterey 12.0, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS Ventura 13.0
- Connectors
- 9 pin USB Type A - male (input)
- 19 pin HDMI Type A - female (output) , 15 pin HD D-Sub (HD-15) - female (output)
- FCC, RoHS, REACH
- 10.5 cm
- 4.3 cm
- 1.4 cm
- 50 g
- Shipping Width
- 14.2 cm
- Shipping Depth
- 17 cm
- Shipping Height
- 3 cm
- Shipping Weight
- 105 g
- Limited warranty - 3 years
StarTech.com USB to Dual HDMI Adapter | In Stock | £72.60 |
StarTech.com USB-C to Dual-HDMI Adapter | In Stock | £103.27 |
