StarTech.com USB to VGA Multi Monitor External Video Adapter
Quicklinx: 660DWS00 Mfr#: USB2VGAE2
12 In Stock
£15.77 ex VAT
£18.92 inc VAT
The USB2VGAE2 USB to VGA external video adapter is the perfect multi-monitor VGA solution for office applications and Internet browsing.
The USB video adapter features a small form factor and enables a USB 2.0 port to be used with a VGA port. A cost-saving multi-monitor or dual display option that can be used as an external graphics card for either laptop or desktop applications.
The USB video adapter can be used with up to four additional (five total) USB2VGAE2 USB video adapters, creating multiple VGA connections that can be used to further extend or mirror the desktop shown on the existing display - all without having to open the computer case to add extra video cards.
StarTech.com USB to VGA Adapter - 1440x900 - adapter - VGA / USB - TAA Compliant - 7.5 cm
Cable
Adapter - VGA / USB
TAA Compliant
Max Output Resolution
1600 x 1200
Length
7.5 cm
Grey
Connector
USB - male (input)
Connector (Second End)
HD-15 (VGA) - female (output)
USB / USB 2.0
P/N: MXT101MM
Cable Type
Adapter
Interface Supported
VGA / USB
Jacket Material
Plastic
USB / USB 2.0
Length
7.5 cm
Grey
Adapters & Converters
1600 x 1200
Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10
Connector
4 pin USB Type A - male (input)
15 pin HD D-Sub (HD-15) - female (output)
FCC, RoHS, WEEE, REACH, RCM
TAA Compliant
4.2 cm
5 cm
80 g
Shipping Width
14.8 cm
Shipping Depth
21 cm
Shipping Height
4 cm
Shipping Weight
235 g
P/N: MXT101MM
660D StarTech.com USB to VGA Multi Monitor External Video Adapter In Stock £15.77
660D StarTech.com USB to VGA External Video Card Multi Monitor Adapter – 1920x1200 In Stock £12.18
660D StarTech.com Slim USB 3.0 to VGA External Video Card Multi Monitor Adapter – 1920x1200 / 1080p In Stock £19.75
660D StarTech.com USB 3.0 VGA Video Adapter In Stock £17.38
660D StarTech.com USB 3.0 to HDMI VGA Adapter - 4K 30 - External Video & Graph In Stock £63.24
