The 1P3FPC-USB-SERIAL 1 Port USB to Serial Adapter lets you add an RS-232 DB9 serial COM port to your laptop or desktop computer, allowing it to control and communicate with a serial peripheral device.
Accessible connectivity
The USB to RS232 cable is a convenient connectivity solution that bridges the gap between current and legacy technologies. The small footprint, data rate of up to 921.6 kbps, COM retention, and 3 ft (0.91 m) cable length makes it the ideal solution for the IT industry, point of sales (POS), industrial applications, AV, and office setups. -
Connect with ease
This adapter cable allows you to easily add a RS-232 DB9 COM port by connecting it to the commonly found USB Type-A port on your host device. This USB 2.0 converter is compatible with other USB revisions. It supports Windows, macOS, and Linux (including the latest versions) for maximum compatibility. 1P3FPC-USB-SERIAL backed for 2-years by StarTech.com, including free lifetime 24/5 multi-lingual technical assistance.
- StarTech.com 3ft (1m) USB to Serial Cable with COM Port Retention, DB9 Male RS232 to USB Converter, Straight Through USB to Serial Adapter for PLC/Printer/Scanner - Prolific IC, Automatic Handshake, Windows/Mac OS - serial adapter - USB - RS-232
- Serial adapter
- Form Factor
- External
- Interface (Bus) Type
- USB
- Ports
- RS-232
- 4.5 cm x 3.4 cm x 1.6 cm
- Length
- 90 cm
- Data Link Protocol
- RS-232
- Data Transfer Rate
- 921.6 Kbps
- System Requirements
- Google Chrome OS, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Apple MacOS X 10.11 - 10.15, Apple macOS 11.0, Linux Kernel 4.15 or later, Apple macOS 12, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 13.0
- 2-year warranty
- Serial adapter
- Form Factor
- External
- USB
- Ports
- RS-232
- Connectivity Technology
- Wired
- RS-232
- 921.6 Kbps
- 1 x RS-232 - 9 pin D-Sub (DB-9)
- Cables Included
- 1 x serial cable - 91 cm
- FCC, RoHS, WEEE, RCM
- OS Required
- 4.5 cm
- 3.4 cm
- 1.6 cm
- Length
- 90 cm
- Shipping Width
- 17 cm
- Shipping Depth
- 14.2 cm
- Shipping Height
- 3 cm
- Shipping Weight
- 102.2 g
- Limited warranty - 2 years
- 0 °C
- 80 °C
- 20 - 80% RH (non-condensing)
StarTech.com 1m Black Straight Through DB9 RS232 Serial Cable - M/F | In Stock | £4.42 |
StarTech.com 3m Black Straight Through DB9 RS232 Serial Cable - M/F | In Stock | £5.02 |
StarTech.com 0.5m Black Straight Through DB9 RS232 Serial Cable - M/F | In Stock | £4.35 |
StarTech.com 1m Black DB9 RS232 Serial Null Modem Cable F/M | In Stock | £4.16 |
StarTech.com 2m Black DB9 RS232 Serial Null Modem Cable F/M | In Stock | £4.57 |
StarTech.com 3ft/1m USB to Serial Cable | In Stock | £32.13 |
StarTech.com 10ft/3m USB to RS232 Serial Adapter | In Stock | £38.56 |
StarTech.com 10ft/3m USB to Null Modem Serial Cable | In Stock | £38.56 |
StarTech.com 3ft (1m) USB to Null Modem Serial Cable | In Stock | £28.71 |
StarTech.com 2ft 2-Port USB to RS232 Serial Adapter | In Stock | £47.73 |
StarTech.com 13ft 2-Port USB to RS232 Serial Adapter | In Stock | £52.47 |
StarTech.com 6.6ft/2m USB to Serial Adapter | In Stock | £29.25 |
StarTech.com USB Serial DCE Adapter Cable 2m | In Stock | £26.01 |
