Connect your serial devices, and transfer your files. The SCNM9FM1MBK 1m DB9 Null Modem Cable features one DB9 male and one DB9 female connector, allowing you to connect a serial device to a 9-pin serial port, or transfer files directly from PC-to-PC via a serial connection.
- StarTech.com 1m Black DB9 RS232 Serial Null Modem Cable F/M - DB9 Male to Female - 9 pin Null Modem Cable - 1x DB9 (M), 1x DB9 (F), Black - null modem cable - DB-9 to DB-9 - 1 m
- Null modem cable
- Length
- 1 m
- Connector
- 9 pin D-Sub (DB-9) - female
- Connector (Second End)
- 9 pin D-Sub (DB-9) - male
- Black
- Limited lifetime warranty
- Designed For
- P/N: 1P3FPC-USB-SERIAL, ICUSB2321F, ICUSB2324, ICUSB2324I, ICUSB232PRO, ICUSB232V2
- Null modem cable
- American Wire Gauge (AWG)
- 28
- Length
- 1 m
- Black
- Connector
- RoHS, EMI
- Designed For
StarTech.com 1m Black DB9 RS232 Serial Null Modem Cable F/M | In Stock | £3.97 |
StarTech.com 2m Black DB9 RS232 Serial Null Modem Cable F/M | In Stock | £4.98 |
