StarTech.com USB to Serial Cable - Win/Mac
Quicklinx: GR5YWS00 Mfr#: 1P3FPC-USB-SERIAL
Wired / Wireless: Wired
Protocol: RS-232
Form Factor: External
Compatibility: [N/A]
Type: Serial adapter
10 In Stock
£23.46 ex VAT
£28.15 inc VAT
The 1P3FPC-USB-SERIAL 1 Port USB to Serial Adapter lets you add an RS-232 DB9 serial COM port to your laptop or desktop computer, allowing it to control and communicate with a serial peripheral device.
  • Accessible connectivity
    The USB to RS232 cable is a convenient connectivity solution that bridges the gap between current and legacy technologies. The small footprint, data rate of up to 921.6 kbps, COM retention, and 3 ft (0.91 m) cable length makes it the ideal solution for the IT industry, point of sales (POS), industrial applications, AV, and office setups.
  • Connect with ease
    This adapter cable allows you to easily add a RS-232 DB9 COM port by connecting it to the commonly found USB Type-A port on your host device. This USB 2.0 converter is compatible with other USB revisions. It supports Windows, macOS, and Linux (including the latest versions) for maximum compatibility. 1P3FPC-USB-SERIAL backed for 2-years by StarTech.com, including free lifetime 24/5 multi-lingual technical assistance.
StarTech.com 3ft (1m) USB to Serial Cable with COM Port Retention, DB9 Male RS232 to USB Converter, Straight Through USB to Serial Adapter for PLC/Printer/Scanner - Prolific IC, Automatic Handshake, Windows/Mac OS - serial adapter - USB - RS-232
Serial adapter
External
Interface (Bus) Type
USB
Ports
RS-232
4.5 cm x 3.4 cm x 1.6 cm
Length
90 cm
RS-232
Data Transfer Rate
921.6 Kbps
Google Chrome OS, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Apple MacOS X 10.11 - 10.15, Apple macOS 11.0, Linux Kernel 4.15 or later, Apple macOS 12, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 13.0
Serial adapter
External
USB
Ports
RS-232
Wired
RS-232
Data Transfer Rate
921.6 Kbps
1 x RS-232 - 9 pin D-Sub (DB-9)
1 x serial cable - 91 cm
FCC, RoHS, WEEE, RCM
4.5 cm
3.4 cm
1.6 cm
Length
90 cm
Shipping Width
17 cm
Shipping Depth
14.2 cm
Shipping Height
3 cm
Shipping Weight
102.2 g
80 °C
20 - 80% RH (non-condensing)
GR5Y StarTech.com 1m Black Straight Through DB9 RS232 Serial Cable - M/F In Stock £4.42
GR5Y StarTech.com 3m Black Straight Through DB9 RS232 Serial Cable - M/F In Stock £5.02
GR5Y StarTech.com 0.5m Black Straight Through DB9 RS232 Serial Cable - M/F In Stock £4.35
GR5Y StarTech.com 1m Black DB9 RS232 Serial Null Modem Cable F/M In Stock £4.16
GR5Y StarTech.com 2m Black DB9 RS232 Serial Null Modem Cable F/M In Stock £4.57
GR5Y StarTech.com 3ft/1m USB to Serial Cable In Stock £32.13
GR5Y StarTech.com 10ft/3m USB to RS232 Serial Adapter In Stock £38.56
GR5Y StarTech.com 10ft/3m USB to Null Modem Serial Cable In Stock £38.56
GR5Y StarTech.com 3ft (1m) USB to Null Modem Serial Cable In Stock £28.71
GR5Y StarTech.com 2ft 2-Port USB to RS232 Serial Adapter In Stock £47.73
GR5Y StarTech.com 13ft 2-Port USB to RS232 Serial Adapter In Stock £52.47
GR5Y StarTech.com USB Serial DCE Adapter Cable 2m In Stock £26.01
Protocol: RS-232
