Add an RS232 serial port to your laptop or desktop computer through USB. The ICUSB232V2 1 Port USB to Serial Adapter converts a USB port into an RS232 DB9 serial port to connect to, monitor, and control a serial device.
Supporting data transfer rates up to 921.6 Kbps, the USB to serial cable is a convenient and cost-saving solution for providing serial connectivity to devices such as point-of-sale terminals, serial modems, industrial equipment, and a wide variety of other RS232 peripherals.
The USB to RS232 converter is easy to install and offers broad operating system compatibility, including Windows 8, Linux and Mac OS, for easy integration into mixed environments.
Durable construction
The integrated design of this USB to Serial RS232 Adapter ensures long-lasting performance, making it a reliable choice for connecting various serial devices. -
Compact length
At 43 cm, this adapter is compact enough for easy storage and portability without sacrificing functionality. -
Fast data transmission
With a data transfer rate of up to 921.6 Kbps, this adapter facilitates efficient data communication between devices. -
Environmentally compliant
The adapter meets FCC and RoHS standards, ensuring it is safe for use and minimizes environmental impact.
- StarTech.com 1 Port USB to Serial RS232 Adapter - Prolific PL-2303 - USB to DB9 Serial Adapter Cable - RS232 Serial Converter (ICUSB232V2) - serial adapter - USB 2.0 - RS-232
- Serial adapter
- Form Factor
- External
- Interface (Bus) Type
- USB 2.0
- Ports
- RS-232
- 52.5 g
- Data Link Protocol
- RS-232
- Data Transfer Rate
- 921.6 Kbps
- System Requirements
- Apple MacOS 9.x, Apple MacOS 8.x, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Linux LTS versions only, Apple MacOS X 10.6 - 10.15, Apple macOS 11.0, Linux Kernel 2.4.31 or later, Microsoft Windows Vista / 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
- 3-year warranty
- Serial adapter
- Form Factor
- External
- USB 2.0
- Ports
- RS-232
- Connectivity Technology
- Wired
- RS-232
- 921.6 Kbps
- 1 x RS-232 - 9 pin D-Sub (DB-9)
- Cables Included
- 1 x USB cable (integrated) - 43 cm
- FCC, RoHS
- OS Required
- 52.5 g
- Limited warranty - 3 years
- 0 °C
- 60 °C
StarTech.com 1 ft USB to RS232 Serial DB9 Adapter Cable with COM Retention | In Stock | £22.73 |
StarTech.com 1 Port Professional USB to Serial Adapter Cable with COM Retention | In Stock | £33.19 |
StarTech.com USB to RS232 DB9/DB25 Serial Adapter Cable - M/M | In Stock | £15.41 |
StarTech.com 10ft USB 2.0 Extension Cable A to A - M/F | In Stock | £5.00 |
StarTech.com 3 ft Black USB 2.0 Extension Cable A to A - M/F | In Stock | £4.06 |
StarTech.com 6 ft Black USB 2.0 Extension Cable A to A - M/F | In Stock | £4.19 |
StarTech.com 1 Port FTDI USB to Serial RS232 Adapter Cable with COM Retention | In Stock | £25.99 |
StarTech.com 3ft USB to RS232 DB9 Serial Adapter Cable - M/M | In Stock | £21.04 |
StarTech.com 1 Port FTDI USB to Serial RS232 Adapter Cable with Optical Isolation | In Stock | £96.60 |
StarTech.com 10m USB 3.0 Active Extension Cable - M/F | In Stock | £115.60 |
StarTech.com 1 Port USB to Null Modem RS232 DB9 Serial DCE Adapter Cable with FTDI | In Stock | £26.44 |
StarTech.com 4 Port USB to DB9 RS232 Serial Adapter Hub – Industrial DIN Rail and Wall Mountable | In Stock | £90.75 |
StarTech.com DB9 to DB25 Serial Cable Adapter - F/M | In Stock | £5.43 |
StarTech.com 8 Port USB to DB9 RS232 Serial Adapter Hub – Industrial DIN Rail and Wall Mountable | In Stock | £151.55 |
StarTech.com 1m Black Straight Through DB9 RS232 Serial Cable - M/F | In Stock | £3.48 |
StarTech.com 3m Black Straight Through DB9 RS232 Serial Cable - M/F | In Stock | £5.02 |
StarTech.com 0.5m Black Straight Through DB9 RS232 Serial Cable - M/F | In Stock | £4.35 |
StarTech.com 1m Black DB9 RS232 Serial Null Modem Cable F/M | In Stock | £4.16 |
StarTech.com 2m Black DB9 RS232 Serial Null Modem Cable F/M | In Stock | £4.57 |
StarTech.com USB to RS232 Serial Adapter | In Stock | £16.74 |
StarTech.com 4 Port USB to Serial Hub | In Stock | £82.13 |
StarTech.com 4-Port USB to Serial Adapter | In Stock | £217.41 |
StarTech.com 8-Port USB to Serial Adapter | In Stock | £347.68 |
