Add 4 DIN Rail-mountable RS232 Serial ports to any system through USB. The ICUSB2324I 4-Port Industrial USB to Serial Hub with DIN Rail Clips converts a single USB port into four RS232 serial ports, enabling you to connect to, monitor and control your serial devices.
Featuring rugged metal construction, with sturdy wall-mounting brackets and top-hat DIN Rail clips (included), this USB to Serial Hub provides versatile mounting options and a robust solution for both harsh industrial environments and simple desktop installations.
This USB powered adapter also retains assigned serial COM port values once connected, allowing the same values to be automatically reassigned to the ports provided by the adapter.
Versatile connectivity options
With four RS-232 ports, this adapter allows users to connect multiple serial devices simultaneously, providing flexibility for industrial and commercial applications. -
Robust temperature operation
This adapter can operate efficiently within a temperature range of 0°C to 55°C, making it suitable for various environments, from office settings to industrial locations. -
Rapid data transfers
Capable of data transfer rates up to 921.6 Kbps, this adapter ensures that large amounts of data can be transmitted quickly and reliably, essential for high-demand applications. -
Compact and convenient design
The wall mount and Din rail form factor make installation straightforward, while its compact nature conserves space in any setup. -
Compliant with standards
This product meets FCC and RoHS compliance standards, ensuring high quality and safety for users, reducing environmental impact.
- StarTech.com 4 Port USB to Serial RS232 Adapter - Wall Mount - Din Rail - COM Port Retention - FTDI USB to DB9 RS232 Hub (ICUSB2324I) - serial adapter - USB 2.0 - RS-232 x 4
- Serial adapter
- Form Factor
- External
- Interface (Bus) Type
- USB 2.0
- Ports
- RS-232 x 4
- 6.65 cm x 15 cm x 2.6 cm
- 450 g
- Data Link Protocol
- RS-232
- Data Transfer Rate
- 921.6 Kbps
- Black
- System Requirements
- Microsoft Windows 98 Second Edition, Microsoft Windows XP Embedded, Microsoft Windows Server 2003, Microsoft Windows CE 5.0, Microsoft Windows CE 4.2, Microsoft Windows Server 2008 R2, Linux 2.4.x or later, Microsoft Windows CE 6.0, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Microsoft Windows Server 2019, Linux LTS versions only, Apple MacOS X 10.6 - 10.15, Apple macOS 11.0, Apple macOS 12.0, Microsoft Windows 11, Apple macOS 13.0
- 2-year warranty
- Serial adapter
- Form Factor
- External
- USB 2.0
- Ports
- RS-232 x 4
- Connectivity Technology
- Wired
- RS-232
- 921.6 Kbps
- USB powered
- 4 x RS-232 - 9 pin D-Sub (DB-9) - male
- Cables Included
- 1 x USB cable (external) - 1.8 m
- FCC, RoHS
- Black
- Software Included
- Drivers & Utilities
- OS Required
- 6.65 cm
- 15 cm
- 2.6 cm
- 450 g
- Limited warranty - 2 years
- 0 °C
- 55 °C
- 5 - 95%
StarTech.com 1 ft USB to RS232 Serial DB9 Adapter Cable with COM Retention | In Stock | £22.01 |
StarTech.com Right Angle DB9 to DB9 Serial Cable Adapter Type 1 - M/F | In Stock | £6.52 |
StarTech.com 1 Port FTDI USB to Serial RS232 Adapter Cable with COM Retention | In Stock | £24.62 |
StarTech.com 1 Port USB to Null Modem RS232 DB9 Serial DCE Adapter Cable with FTDI | In Stock | £25.80 |
StarTech.com 4 Port USB to DB9 RS232 Serial Adapter Hub – Industrial DIN Rail and Wall Mountable | In Stock | £91.11 |
StarTech.com 8 Port USB to DB9 RS232 Serial Adapter Hub – Industrial DIN Rail and Wall Mountable | In Stock | £152.14 |
StarTech.com 1m Black Straight Through DB9 RS232 Serial Cable - M/F | In Stock | £4.24 |
StarTech.com 2m Black Straight Through DB9 RS232 Serial Cable - M/F | In Stock | £4.81 |
StarTech.com 3m Black Straight Through DB9 RS232 Serial Cable - M/F | In Stock | £5.16 |
StarTech.com 0.5m Black Straight Through DB9 RS232 Serial Cable - M/F | In Stock | £4.22 |
StarTech.com 1m Black DB9 RS232 Serial Null Modem Cable F/M | In Stock | £4.00 |
StarTech.com 2m Black DB9 RS232 Serial Null Modem Cable F/M | In Stock | £4.67 |
StarTech.com USB to RS232 Serial Adapter | In Stock | £16.69 |
StarTech.com 16-Port USB-Serial Adapter Hub | In Stock | £415.42 |
StarTech.com 4 Port USB to Serial Hub | In Stock | £78.99 |
StarTech.com 4-Port USB to Serial Adapter | In Stock | £218.26 |
StarTech.com 8-Port USB to Serial Adapter | In Stock | £350.31 |
