StarTech.com USB to RS232 Serial Adapter
Quicklinx: 95Q0WS00 Mfr#: ICUSB232V2
Type: Serial adapter
Compatibility: Mac, PC
Interface: USB 2.0
43 In Stock
£16.69 ex VAT
£20.02 inc VAT
Add an RS232 serial port to your laptop or desktop computer through USB. The ICUSB232V2 1 Port USB to Serial Adapter converts a USB port into an RS232 DB9 serial port to connect to, monitor, and control a serial device.
Supporting data transfer rates up to 921.6 Kbps, the USB to serial cable is a convenient and cost-saving solution for providing serial connectivity to devices such as point-of-sale terminals, serial modems, industrial equipment, and a wide variety of other RS232 peripherals.
The USB to RS232 converter is easy to install and offers broad operating system compatibility, including Windows 8, Linux and Mac OS, for easy integration into mixed environments.
  • Durable construction
    The integrated design of this USB to Serial RS232 Adapter ensures long-lasting performance, making it a reliable choice for connecting various serial devices.
  • Compact length
    At 43 cm, this adapter is compact enough for easy storage and portability without sacrificing functionality.
  • Fast data transmission
    With a data transfer rate of up to 921.6 Kbps, this adapter facilitates efficient data communication between devices.
  • Environmentally compliant
    The adapter meets FCC and RoHS standards, ensuring it is safe for use and minimizes environmental impact.
StarTech.com 1 Port USB to Serial RS232 Adapter - Prolific PL-2303 - USB to DB9 Serial Adapter Cable - RS232 Serial Converter (ICUSB232V2) - serial adapter - USB 2.0 - RS-232
Serial adapter
External
Interface (Bus) Type
USB 2.0
Ports
RS-232
52.5 g
RS-232
Data Transfer Rate
921.6 Kbps
Apple MacOS 9.x, Apple MacOS 8.x, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Linux LTS versions only, Apple MacOS X 10.6 - 10.15, Apple macOS 11.0, Linux Kernel 2.4.31 or later, Microsoft Windows Vista / 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
3-year warranty
Serial adapter
External
USB 2.0
Ports
RS-232
Wired
RS-232
Data Transfer Rate
921.6 Kbps
1 x RS-232 - 9 pin D-Sub (DB-9)
1 x USB cable (integrated) - 43 cm
FCC, RoHS
52.5 g
Limited warranty - 3 years
60 °C
95Q0 StarTech.com 1 ft USB to RS232 Serial DB9 Adapter Cable with COM Retention In Stock £22.01
95Q0 StarTech.com 1 Port Professional USB to Serial Adapter Cable with COM Retention In Stock £33.15
95Q0 StarTech.com USB to RS232 DB9/DB25 Serial Adapter Cable - M/M In Stock £14.05
95Q0 StarTech.com 10ft USB 2.0 Extension Cable A to A - M/F In Stock £5.02
95Q0 StarTech.com 3 ft Black USB 2.0 Extension Cable A to A - M/F In Stock £4.15
95Q0 StarTech.com 6 ft Black USB 2.0 Extension Cable A to A - M/F In Stock £4.29
95Q0 StarTech.com 1 Port FTDI USB to Serial RS232 Adapter Cable with COM Retention In Stock £24.62
95Q0 StarTech.com 3ft USB to RS232 DB9 Serial Adapter Cable - M/M In Stock £21.15
95Q0 StarTech.com 1 Port FTDI USB to Serial RS232 Adapter Cable with Optical Isolation In Stock £98.51
95Q0 StarTech.com 10m USB 3.0 Active Extension Cable - M/F In Stock £117.90
95Q0 StarTech.com 1 Port USB to Null Modem RS232 DB9 Serial DCE Adapter Cable with FTDI In Stock £25.80
95Q0 StarTech.com 4 Port USB to DB9 RS232 Serial Adapter Hub – Industrial DIN Rail and Wall Mountable In Stock £92.54
95Q0 StarTech.com DB9 to DB25 Serial Cable Adapter - F/M In Stock £5.51
95Q0 StarTech.com 8 Port USB to DB9 RS232 Serial Adapter Hub – Industrial DIN Rail and Wall Mountable In Stock £154.54
95Q0 StarTech.com 1m Black Straight Through DB9 RS232 Serial Cable - M/F In Stock £4.24
95Q0 StarTech.com 2m Black Straight Through DB9 RS232 Serial Cable - M/F In Stock £4.81
95Q0 StarTech.com 3m Black Straight Through DB9 RS232 Serial Cable - M/F In Stock £5.16
95Q0 StarTech.com 0.5m Black Straight Through DB9 RS232 Serial Cable - M/F In Stock £4.22
95Q0 StarTech.com 1m Black DB9 RS232 Serial Null Modem Cable F/M In Stock £4.00
95Q0 StarTech.com 2m Black DB9 RS232 Serial Null Modem Cable F/M In Stock £4.67
95Q0 StarTech.com USB to RS232 Serial Adapter In Stock £16.69
95Q0 StarTech.com 4 Port USB to Serial Hub In Stock £82.40
95Q0 StarTech.com UCB C to Serial Adapter In Stock £17.40
95Q0 StarTech.com 8-Port USB to Serial Adapter In Stock £355.84
Compatibility: Mac
Compatibility: PC
Interface: USB 2.0
