StarTech.com USB to DVI External Dual or Multi Monitor Video Adapter
Quicklinx: 6LCRWS00 Mfr#: USB2DVIE2
Connect a DVI display for an entry-level extended desktop multi-monitor USB solution. The USB2DVIE2 USB DVI Multi Monitor External Video Adapter turns an available USB 2.0 port into an external video card DVI port - providing high quality dual-display or multi-monitor capability that can be used in a variety of laptop or desktop applications to increase your productivity.
The device also offers the option of running up to five additional displays simultaneously (using five USB2DVIE2 Multi Monitor External Video Cards). Each connected adapter can be used to further extend the desktop or mirror the image shown on the existing display - all without having to open the computer case to install an additional video card.
StarTech.com USB DVI External Dual or Multi Monitor Video Adapter - external video adapter - 16 MB - black
External video adapter
Bus Type
USB 2.0
16 MB
Max Resolution
1680 x 1050
DVI-I (Single-Link)
5.3 cm x 9.1 cm x 1.8 cm
Enclosure Colour
P/N: DVIDDMM10, DVIDDMM6, DVIDSMM10, DVIMM6, DVISPL1DD, HDDVIMM3, HDMIDVIMM10, HDMIDVIMM6
Bus Type
USB 2.0
Max Resolution
1680 x 1050
DVI-I (Single-Link)
Size
16 MB
Video Output
Colours Max Resolution (external)
32-bit colour
Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Windows 10 (32/64 bits)
Additional Requirements
SVGA monitor, USB 2.0 port
System Requirements Details
Windows 2000/XP/Vista
1 x USB cable
Software Included
Drivers & Utilities
WHQL, FCC, RoHS
5.3 cm
9.1 cm
1.8 cm
108 g
Enclosure Colour
6LCR StarTech.com DVI to VGA Cable Adapter - M/F In Stock £4.87
6LCR StarTech.com HDMI to DVI-D Video Cable Adapter - F/M In Stock £7.55
