Convert and extend a 10/100 Mbps Ethernet connection up to 18.6 miles/30km over Single Mode SC fiber. The ET90110SM302 10/100 Mbps Single Mode Fiber Media Converter SC (30 km) lets you extend a Fast Ethernet network (10/100) over single mode fiber, at distances up to 30 km (18.6 miles).
A cost-effective solution for connecting a 10/100 Mbps Ethernet (10/100Base-T) network to remote network segments over a 100Base-FX fiber backbone, the media converter is designed to offer a durable and convenient Ethernet to fiber solution, with an all-steel chassis, and simple plug-and-play installation with minimal configuration required.
For added versatility, this fiber media converter supports standalone operation, or installation into the 20 Slot, 2U Rackmount Chassis (ETCHS2U).
- StarTech.com 10/100 Mbps Single Mode Fiber Media Converter SC - 18.6 miles/30km over Single Mode SC Fiber (ET90110SM302) - fibre media converter - 10Mb LAN, 100Mb LAN
- Fibre media converter - RJ-45 / SC single-mode
- Form Factor
- External
- Localisation
- North America, United Kingdom, Europe
- Cabling Type
- 100Base-FX
- Data Transfer Rate
- 100 Mbps
- Optical Wave Length
- 1310 nm
- Data Link Protocol
- Max Transfer Distance
- 30 km
- Power
- AC 120/230 V
- 9.5 cm x 16 cm x 2 cm
- 0.6 kg
- 2-year warranty
- Designed For
- P/N: ETCHS2U, SVA12M2NEUA, SVA12M5NA
- Form Factor
- External
- Black
- Localisation
- Connectivity Technology
- Wired
- Cabling Type
- 100Base-FX
- 100 Mbps
- 1310 nm
- 30 km
- Auto-uplink (auto MDI/MDI-X), half duplex mode, full duplex mode, rugged
- 1 x network - RJ-45 female , 1 x Ethernet 100Base-FX - SC single-mode female x 2
- FCC, RoHS
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- 9.5 cm
- 16 cm
- 2 cm
- 0.6 kg
- Limited warranty - 2 years
- 0 °C
- 60 °C
- 10 - 90%
- Designed For
StarTech.com DC Power Adapter - 12V, 2A | In Stock | £11.76 |
StarTech.com DC Power Adapter - 12V, 5A | In Stock | £42.05 |
