StarTech.com USB to DVI Adapter - External USB Video Graphics Card for PC and MAC- 1920x1200
Quicklinx: 8M4JWS00 Mfr#: USB2DVIPRO2
Hurry, only 2 left in stock!
£65.01 ex VAT
£78.01 inc VAT
Connect a DVI display for an extended desktop multi-monitor USB solution. The USB2DVIPRO2 USB to DVI Adapter functions as an external graphics card for Windows and Mac computers - the perfect solution for turning your desktop or laptop computer into a dual or multi-monitor environment, all through the simplicity and convenience of USB.
The USB-DVI Adapter delivers high quality video (up to 1920x1200) for a variety of applications and is capable of simultaneously running up to five additional displays from a single computer (using four USB2DVIPRO2 External Video Adapters). The adapter connects to a host computer through a USB 2.0 port, acting as an external DVI video card to either extend or mirror the desktop shown on the existing display - without having to open the computer case.
Featuring driver support for Microsoft Windows (including Aero themes) and Mac OS X, and with video support for resolutions up to 1920x1200, this USB-DVI video adapter is the ideal solution for a wide range of operating environments as well as large-screen displays/monitors.
  • High resolution support
    The adapter supports a maximum output resolution of 1920 x 1200, ensuring crisp and detailed visuals for a variety of applications.
  • Dual monitor capability
    By connecting two displays, this adapter allows for increased screen real estate, facilitating improved productivity in tasks that require multiple windows.
  • Broad system compatibility
    It is designed to work seamlessly with both Mac and Windows operating systems, making it an ideal choice for diverse user environments.
  • User-friendly features
    The LED status indicator provides at-a-glance information about the adapter's connection status, enhancing user experience during setup and operation.
  • Memory enhanced performance
    Includes 16 MB of built-in memory, which helps to optimize performance when handling high-resolution graphics and video.
StarTech.com USB to DVI Adapter - 1920x1200 - External Video & Graphics Card - Dual Monitor Display Adapter Cable - Supports Mac & Windows (USB2DVIPRO2) - USB / DVI adapter - USB to DVI-I - 27 m
USB / DVI adapter
1920 x 1200 (WUXGA) support, LED status indicator, 16 MB memory
Length
27 m
Connector
4 pin USB Type A - male (input)
Connector (Second End)
24+5 pin combined DVI - female (output)
USB / USB 2.0
P/N: DVIDDMM10, DVIDDMM6, DVIDSMM10, DVIMM6, DVISPL1DD, HDDVIMM3, HDMIDVIMM10, HDMIDVIMM6
USB / DVI adapter
Length
27 m
5.5 cm
2 cm
70 g
Connector
DVI to VGA adapter
USB / USB 2.0, FCC, RoHS
Shipping Width
21.1 cm
Shipping Depth
14.6 cm
Shipping Height
4.2 cm
Shipping Weight
245 g
8M4J StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £7.80
8M4J StarTech.com USB 3.0 to DVI / VGA External Video Card Multi Monitor Adapter – 2048x1152 In Stock £66.16
8M4J StarTech.com USB to DVI Adapter - External USB Video Graphics Card for PC and MAC- 1920x1200 In Stock £65.01
