StarTech.com USB 3.0 to DVI / VGA External Video Card Multi Monitor Adapter – 2048x1152
Quicklinx: 84PDWS00 Mfr#: USB32DVIPRO
£66.16 ex VAT
£79.39 inc VAT
Connect a DVI display through SuperSpeed USB 3.0, for an accelerated external multi-monitor solution at resolutions up to 2048x1152. The USB32DVIPRO USB 3.0 to DVI Adapter turns an available USB 3.0 port into a DVI output, with high resolution 2048x1152 video support - a convenient external video solution that makes it easy to add multi-monitor capability to a USB 3.0-enabled desktop or laptop computer (optimal performance from USB 3.0, backward compatible with USB 2.0). Leveraging the high-bandwidth (5 Gbps) SuperSpeed USB 3.0 interface, the adapter functions as an external graphics card to deliver smooth, high-resolution content to your DVI or VGA-capable display (DVI to VGA Adapter included). The adapter can be used to mirror your primary desktop, showing the same image on each display, or to extend your desktop to double your workspace and increase your productivity.
StarTech.com USB 3.0 to DVI / VGA Adapter - 2048x1152 - External Video & Graphics Card - Dual Monitor Display Adapter Cable - Supports Mac & Windows (USB32DVIPRO) - USB / DVI adapter - USB Type A to DVI-I - 15.2 cm
USB / DVI adapter
2048 x 1152 support, plastic housing, 512 MB memory
Length
15.2 cm
Connector
9 pin USB Type A - male (input)
Connector (Second End)
24+5 pin combined DVI - female (output)
USB / USB 2.0 / USB 3.0
P/N: DVIDDMM10, DVIDDMM6, DVIDSMM10, DVIMM6, DVISPL1DD, HDDVIMM3, HDMIDVIMM10, HDMIDVIMM6
USB / DVI adapter
Length
15.2 cm
4.35 cm
7.8 cm
1.55 cm
91 g
Connector
DVI to VGA adapter
USB / USB 2.0 / USB 3.0, FCC, RoHS, DisplayLink Plug and Display
Shipping Width
14.4 cm
Shipping Depth
17.1 cm
Shipping Height
3 cm
Shipping Weight
211 g
84PD StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £7.92
84PD StarTech.com USB 3.0 to DVI / VGA External Video Card Multi Monitor Adapter – 2048x1152 In Stock £66.16
84PD StarTech.com USB 3.0 to HDMI and DVI Dual Monitor External Video Card Adapter In Stock £42.49
84PD StarTech.com USB to DVI Adapter - External USB Video Graphics Card for PC and MAC- 1920x1200 In Stock £65.01
84PD StarTech.com USB 3.0 to HDMI External Multi Monitor Video Graphics Adapter for Mac & PC In Stock £48.92
