StarTech.com USB to Dual HDMI Adapter
Quicklinx: GVKFWS00 Mfr#: 107B-USB-HDMI
More than 50 In Stock
£45.84 ex VAT
£55.00 inc VAT
This USB to Dual HDMI Adapter enables the addition of two independent HDMI displays (1x 4K & 1x 1080p) to your computer, using a single USB Type-A 3.2 Gen 1 (5 Gbps) connection.
  • Increase Productivity with Multiple Displays
    This USB to HDMI Dual Monitor Adapter features two video outputs, boosting productivity by connecting up to two displays using a single USB Type-A or C port. The adapter is bus-powered, lightweight, and features an integrated 4.3" (11cm) USB cable, making it ideal for transitioning between the office, home, or connecting to displays in a boardroom.
  • 4K Resolution
    Connect a 4K 30Hz and a 1080p display to a laptop or desktop. The USB to Multi-Monitor Adapter supports extended or mirrored display modes, and ultrawide displays, providing additional viewing space.
  • Wide-Ranging System Compatibility
    The USB video adapter is compatible with Windows, macOS, and Chrome OS. The integrated USB-A to USB-C dongle ensures USB compatibility with any host running a supported operating system. The attached 4.3in (11cm) cable is convenient for on the go use. 107B-USB-HDMI is backed for 3-years by StarTech.com, including free 24/5 multi-lingual technical assistance.
StarTech.com USB to Dual HDMI Adapter, USB A/C to 2x HDMI Monitors (1x 4K 30Hz, 1x 1080p), Integrated USB-A to C Dongle, 4in/11cm Cable, Windows & macOS - USB 3.0 to HDMI Multi-Monitor Display Adapter for Laptop (107B-USB-HDMI) - adapter - HDMI / USB
Cable
Adapter - HDMI / USB
Max Output Resolution
3840 x 2160 - 30 Hz
Grey
Connectors
USB Type A - female , 24 pin USB-C - female
Connectors (Second End)
2 x HDMI - male
USB 3.2 Gen 1
4K support
3-year warranty
Cable Type
Adapter 4K support
Interface Supported
HDMI / USB
USB 3.2 Gen 1
USB powered, Silicon Motion SM768 chipset
Grey
Adapters & Converters
3840 x 2160
Refresh Rate
30 Hz
Microsoft Windows 7 / 8.1 / 10 / 11, Apple macOS Mojave 10.14, Apple macOS Catalina 10.15, Apple macOS Big Sur 11.0, Apple macOS Monterey 12.0, Apple macOS Ventura 13.0, Google Chrome OS
Connectors
9 pin USB Type A - female , 24 pin USB-C - female
2 x 19 pin HDMI Type A - male
RoHS, WEEE, HDCP
10 cm
5 cm
1.5 cm
83 g
Shipping Width
13.5 cm
Shipping Depth
8.5 cm
Shipping Height
2 cm
Limited warranty - 3 years
GVKF StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £9.52
GVKF StarTech.com 3ft Premium Certified HDMI 2.0 In Stock £12.15
GVKF StarTech.com 6ft Premium Certified HDMI 2.0 In Stock £17.51
GVKF StarTech.com 10ft Premium Certified HDMI In Stock £18.52
GVKF StarTech.com USB-C to Dual-HDMI Adapter In Stock £96.13
