Connect two 4K 60Hz HDMI displays to the USB Type-C or Type-A port of a laptop/desktop computer, using this USB-C to Dual-HDMI Adapter.
Power Delivery Pass-Through
The USB video adapter features USB Power Delivery (PD) 3.0 pass-through (up to 100W), enabling powering and charging of a laptop when connected to a USB-C power adapter. The adapter runs on USB bus-power when no USB-C power adapter is connected. PD 3.0 features Fast Role Swap (FRS) that prevents USB data disruption when USB-C power is disconnected and the adapter switches to USB bus power. -
DisplayLink Certified 4K 60Hz Resolution
The USB multi-monitor adapter is DisplayLink Certified and supports high-performance dual-monitor 4K 60Hz video resolutions with an integrated DisplayLink DL-6950 Controller. -
Comprehensive Compatibility
The USB video adapter is compatible with Windows, macOS, Ubuntu, and Chrome OS. The integrated USB-C to USB-A adapter enables the flexibility of connecting to any host that is running a compatible operating system. The built-in 1ft (30cm) USB-C/A cable is ideal for on the go use. The length of the cable and the strain reliefs reduce connector/port strain. This product is backed for 3-years by StarTech.com, including free 24/5 multi-lingual technical assistance.
- Startech USB-C to Dual-HDMI Adapter, USB-C or A to 2x HDMI, 4K 60Hz, 100W PD Pass-Through, 1ft (30cm) Built-in Cable, External Video Graphics Adapter - USB to HDMI Multi-Monitor Converter for Laptop (109B-USBC-HDMI) - adapter - HDMI / USB - TAA Compliant - 30 cm
- Cable
- Adapter - HDMI / USB
- TAA Compliant
- Max Output Resolution
- 3840 x 2160 - 60 Hz
- Cable Length
- 30 cm
- Grey
- Connectors
- USB Type A - male , USB-C - male
- Connectors (Second End)
- 2 x HDMI - female
- USB 3.2 Gen 1
- 4K support, active adapter
- 3-year warranty
- Cable Type
- Adapter 4K support, active
- Interface Supported
- HDMI / USB
- USB 3.2 Gen 1
- Cable Length
- 30 cm
- Bus powered, 100W power delivery, aluminum enclosure, Host USB-C Power Adapter
- Grey
Adapters & Converters
- 3840 x 2160
- Refresh Rate
- 60 Hz
- OS Required
- Google Chrome OS, Apple MacOS Sierra, Apple macOS Mojave 10.14, Ubuntu 18.04, Apple macOS Catalina 10.15, Apple macOS Big Sur 11.0, Ubuntu 20.04, Apple macOS Monterey 12.0, Microsoft Windows 7 / 8 / 10 / 11, Apple macOS Ventura 13.0, Apple macOS X El Capitan
- Connectors
- 9 pin USB Type A - male , 24 pin USB-C - male
- 2 x 19 pin HDMI Type A - female
- FCC, RoHS, WEEE, UKCA, DisplayLink certified
- TAA Compliant
- 11.3 cm
- 2.4 cm
- 1.5 cm
- 121 g
- Shipping Width
- 11.4 cm
- Shipping Depth
- 6 cm
- Shipping Height
- 1.6 cm
- Shipping Weight
- 180 g
- Limited warranty - 3 years
StarTech.com 3ft (1m) HDMI 2.1 Cable 8K - Certified Ultra High Speed HDMI | In Stock | £16.49 |
StarTech.com 6ft (2m) HDMI 2.1 Cable 8K - Certified Ultra High Speed HDMI | In Stock | £21.31 |
StarTech.com 10ft Ultra High Speed HDMI 2.1 | In Stock | £24.71 |
