This USB to Dual HDMI Adapter enables the addition of two independent HDMI displays (1x 4K & 1x 1080p) to your computer, using a single USB Type-A 3.2 Gen 1 (5 Gbps) connection.
Increase Productivity with Multiple Displays
This USB to HDMI Dual Monitor Adapter features two video outputs, boosting productivity by connecting up to two displays using a single USB Type-A or C port. The adapter is bus-powered, lightweight, and features an integrated 4.3" (11cm) USB cable, making it ideal for transitioning between the office, home, or connecting to displays in a boardroom. -
4K Resolution
Connect a 4K 30Hz and a 1080p display to a laptop or desktop. The USB to Multi-Monitor Adapter supports extended or mirrored display modes, and ultrawide displays, providing additional viewing space. -
Wide-Ranging System Compatibility
The USB video adapter is compatible with Windows, macOS, and Chrome OS. The integrated USB-A to USB-C dongle ensures USB compatibility with any host running a supported operating system. The attached 4.3in (11cm) cable is convenient for on the go use. 107B-USB-HDMI is backed for 3-years by StarTech.com, including free 24/5 multi-lingual technical assistance.
- StarTech.com USB to Dual HDMI Adapter, USB A/C to 2x HDMI Monitors (1x 4K 30Hz, 1x 1080p), Integrated USB-A to C Dongle, 4in/11cm Cable, Windows & macOS - USB 3.0 to HDMI Multi-Monitor Display Adapter for Laptop (107B-USB-HDMI) - adapter - HDMI / USB
- Cable
- Adapter - HDMI / USB
- Max Output Resolution
- 3840 x 2160 - 30 Hz
- Grey
- Connectors
- USB Type A - female , 24 pin USB-C - female
- Connectors (Second End)
- 2 x HDMI - male
- USB 3.2 Gen 1
- 4K support
- 3-year warranty
- Cable Type
- Adapter 4K support
- Interface Supported
- HDMI / USB
- USB 3.2 Gen 1
- USB powered, Silicon Motion SM768 chipset
- Grey
Adapters & Converters
- 3840 x 2160
- Refresh Rate
- 30 Hz
- OS Required
- Microsoft Windows 7 / 8.1 / 10 / 11, Apple macOS Mojave 10.14, Apple macOS Catalina 10.15, Apple macOS Big Sur 11.0, Apple macOS Monterey 12.0, Apple macOS Ventura 13.0, Google Chrome OS
- Connectors
- 9 pin USB Type A - female ¦ 24 pin USB-C - female
- 2 x 19 pin HDMI Type A - male
- RoHS, WEEE, HDCP
- 10 cm
- 5 cm
- 1.5 cm
- 83 g
- Shipping Width
- 13.5 cm
- Shipping Depth
- 8.5 cm
- Shipping Height
- 2 cm
- Limited warranty - 3 years
StarTech.com 6 ft HDMI to DVI-D Cable - M/M | In Stock | £7.80 |
StarTech.com 3ft Premium Certified HDMI 2.0 | In Stock | £10.97 |
StarTech.com 6ft Premium Certified HDMI 2.0 | In Stock | £12.98 |
StarTech.com 10ft Premium Certified HDMI | In Stock | £15.57 |
StarTech.com USB-C to Dual-HDMI Adapter | In Stock | £86.45 |
