StarTech.com USB HDD dock for SATA & IDE
Quicklinx: B3B2WS00 Mfr#: UNIDOCKU33
Type: Storage controller
HD Size: 2.5, 3.5
Power Supply: Power adapter
  • Windows 8 (32/64 bits)
  • Windows 8.1 (32/64 bits)
18 In Stock
£62.76 ex VAT
£75.31 inc VAT
Connect both an IDE and a SATA 2.5/3.5in hard drive or solid state drive to your computer system using an available USB 3.0 port, with support for UASP for optimal performance. The UNIDOCKU33 USB 3.0 Universal HDD / SSD Dock enables you to instantly access your 2.5 or 3.5in IDE and SATA hard drives through two top loading drive slots, saving you the hassle of mounting the drives into a computer or external enclosure or tray.
Enhanced with UASP (USB Attached SCSI Protocol), this hard drive docking station lets you get the most out of the fastest drive technologies such as SATA III (6 Gbps), solid state drives (SSD) and hybrid, drives with performance up to 70% faster than conventional USB 3.0 when paired with a UASP-enabled host controller.
The slot-loading design holds the SATA and IDE drives upright inside the docks, neatly keeping them off the desk, for convenience and a clutter-free setup. For SATA drives, the HDD can be inserted and connected directly through the designated dock slot, while the IDE drive slot is conveniently positioned near the rear panel 40-pin data and LP4 power connections, making it easy to connect to the dock using the included IDE data and power cables.
A single USB 3.0 connection to your host computer, enables access to both the IDE & SATA hard drives simultaneously - a convenient solution for migrating data from an IDE drive to a SATA drive or vice versa. The dock can also be used to greatly increase the storage and backup capabilities of your computer system with support for high capacity drives (tested with up to 6TB 3.5" and 2TB 2.5" drives).
UASP is supported in Windows 8, Mac OSX (10.8 or above), and Linux. In testing, UASP performs with a 70% faster read speed and 40% faster write speed over traditional USB 3.0 at peak performance.
At the same peak in testing UASP also shows an 80% reduction in required processor resources.
Testing results were obtained using an Intel Ivy Bridge system, a UASP-enabled StarTech.com Enclosure, and a SATA III solid state drive.
  • Versatile connectivity
    This docking station offers a blend of SATA and IDE interfaces, accommodating both modern and legacy hard drives. With support for 2.5" and 3.5" drives, it ensures compatibility across a wide range of SSD and HDD formats, making it an essential tool for data migration and drive cloning.
  • High-speed data transfer
    Equipped with USB 3.0 technology, the docking station provides a data transfer rate of up to 6 Gbit/s. This speed enhancement, coupled with the UASP transfer protocol, ensures faster read/write speeds for efficient data management and backup processes.
  • Easy drive management
    Featuring hot-swap and top-accessible bays, this docking station simplifies the process of swapping drives without the need to reboot your system. Its Plug-and-Play functionality, supported by LED indicators, offers a user-friendly experience for both novice and experienced users alike.
StarTech.com Dual-Bay USB 3.0 to SATA and IDE Hard Drive Docking Station, USB Hard Drive Dock, External 2.53.5 SATA III and IDE (40 pin) SSDHDD Docking Station, Hot-Swap Hard Drive Bays - Top-Loading - storage controller - ATA / SATA 6Gb/s - USB 3.0
Storage controller - external
Bus Type
USB 3.0
Expansion Bays
1 x hot-swap - 2.5" / 3.5" shared , 1 x top accessible - 2.5" / 3.5" shared
Hard Drive Form Factor Compatibility
2.5", 3.5"
ATA / SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Hard drive, solid state drive
Max Storage Devices Qty
2
Product Material
Plastic
AC 120/230 V
Linux, Apple MacOS X 10.6, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Google Chrome OS, Apple MacOS X Lion 10.7, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits), Windows 8.1 (32/64 bits), Apple OS X 10.9 Mavericks
14 cm x 13 cm x 7 cm
610 g
P/N: SVA12M5NA
2.5", 3.5"
Host Bus
USB 3.0
Product Material
Plastic
Storage Controller
ATA / SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
2
JMicron JMS561U / JMD330
Bays
1 x SATA 6Gb/s - SATA combo (internal (bay1)) , 1 x ATA-133 - 40 PIN IDC (rear)
1 x USB 3.0 - 9 pin USB Type B
1 x USB 3.0 cable - external , 2 x IDE cable - external
LED indicator, tested with up to 1TB 5400 RPM 2.5” hard drives, tested with up to 6TB 7200 RPM hard drives, UASP transfer protocol
MTBF
30,000 hours
Plug and Play, FCC, RoHS
Power adapter
AC 120/230 V
14 cm
13 cm
7 cm
610 g
5 °C
80 °C
8 - 90%
P/N: SVA12M5NA
B3B2 StarTech.com 2.5in Silicone Laptop Hard Drive Protector Sleeve with Connector Cap In Stock £3.33
B3B2 StarTech.com 2 port PCI Express SuperSpeed USB 3.0 Card with UASP Support - 1 Internal 1 External In Stock £27.76
B3B2 StarTech.com SATA to 2.5in or 3.5in IDE Hard Drive Adapter for HDD Docks In Stock £19.65
B3B2 StarTech.com DC Power Adapter - 12V, 5A In Stock £42.05
HD Size: 2.5
HD Size: 3.5
