The SAT2IDEADP SATA to IDE hard drive adapter allows for 2.5in/3.5in IDE-based (PATA) hard drives (HDD) to be used in most StarTech.com SATA-based HDD docking stations and drive duplicators. The unique mounting style of the SATA/IDE adapter enables it to be easily mounted to IDE/ATA hard drive and inserted into SATA hard drive dock bay, for quick and easy retrieval of data from older HDDs while its all- metal construction ensures maximum durability. The SAT2IDEADP hard drive adapter works with most StarTech.com SATA HDD Docking Stations and Duplicators, including: SATADOCK22UE, SATDOCK2UEGB, SATDOCK22RE, SATDOCK22R, SATDOCKU3S, SATADOCKU2, SATADOCKU2E, SATDOCK4U2E, SATDOCK4U3E, SATDOCKCRH, SATDOCKU2EGB, SATDOCKU2GB. Fully compatible with both 2.5in and 3.5in form factor hard drives and up to ATA-133 (133 MBps), this versatile HDD adapter can also be used to install IDE hard drives into SATA-only desktop computers, or many other scenarios that require an IDE HDD be connected through SATA.
Versatile compatibility
The adapter supports both 2.5-inch and 3.5-inch hard drives, making it versatile for various storage needs. -
Efficient data handling
With a data transfer rate of 133 MBps, this controller ensures efficient data management and quicker access time. -
Robust environmental tolerance
It operates effectively in temperatures ranging from 5°C to 80°C and a humidity level of 8 to 90%, making it reliable in diverse conditions. -
Compliant with standards
The product adheres to FCC and RoHS standards, ensuring quality while being environmentally friendly. -
Internal storage efficiency
Designed for internal use, the adapter is perfect for integrating into existing systems for enhanced storage capabilities.
- StarTech.com SATA to 2.5in or 3.5in IDE Hard Drive Adapter for HDD Docks - SATA to IDE Converter - HDD Docking Station (SAT2IDEADP) - storage controller - ATA-133 - SATA
- Storage controller - internal
- Bus Type
- SATA
- Hard Drive Form Factor Compatibility
- 2.5", 3.5"
- Interface
- ATA-133
- Data Transfer Rate
- 133 MBps
- Supported Devices
- Hard drive
- Channel Qty
- 1
- 7.8 cm x 10.1 cm x 2.6 cm
- 104 g
- 2-year warranty
- Designed For
- P/N: SATDOCK2REU3, SATDOCK4U3RE, SATDOCK5U3ER, SATDUP11, SATDUP11IMG, SATERASER4, SATSASDUPE11, SDOCK2ERU33, SDOCK2U313R, SDOCK2U33, SDOCK2U33EB, SDOCK2U33RE, SDOCK2U33V, SDOCK4U313, SDOCK4U33, SDOCKU313, SDOCKU313E, SDOCKU33BV, SDOCKU33EBV, SDOCKU33EF, SDOCKU33HW, SU2DUPERA11, UNIDOCKU33
- 2.5", 3.5"
- Host Bus
- SATA
Storage Controller
- Interface
- ATA-133
- 133 MBps
- Supported Devices
- Hard drive
- Channel Qty
- 1
- 1 x ATA-133 - 40 PIN IDC
- Connections
- 1 storage - Serial ATA-150 - 7 pin Serial ATA
- FCC, RoHS
- Limited warranty - 2 years , Technical support - lifetime
- 7.8 cm
- 10.1 cm
- 2.6 cm
- 104 g
- 5 °C
- 80 °C
- 8 - 90%
- Designed For
- P/N: SATDOCK2REU3, SATDOCK4U3RE, SATDOCK5U3ER, SATDOCKU3S, SATDUP11, SATDUP11IMG, SATERASER4, SATSASDUPE11, SDOCK2ERU33, SDOCK2U313R, SDOCK2U33, SDOCK2U33EB, SDOCK2U33RE, SDOCK2U33V, SDOCK4U313, SDOCK4U33, SDOCKU313, SDOCKU313E, SDOCKU33BV, SDOCKU33EBV, SDOCKU33EF, SDOCKU33HW, SU2DUPERA11, UNIDOCKU33
StarTech.com 3.5in Hard Drive to 5.25in Front Bay Bracket Adapter | In Stock | £5.45 |
StarTech.com Bi-Directional SATA IDE Adapter Converter | In Stock | £11.97 |
StarTech.com USB 3.0 to SATA Hard Drive Docking Station for 2.5/3.5 HDD | In Stock | £40.39 |
StarTech.com SATA to 2.5in or 3.5in IDE Hard Drive Adapter for HDD Docks | In Stock | £19.16 |
StarTech.com 2.5" to 3.5" SATA Aluminium Hard Drive Adapter Enclosure SSD / HDD Height up to 12.5mm | In Stock | £19.99 |
StarTech.com USB 3.0 to eSATA HDD / SSD / ODD Adapter Cable - 3ft eSATA Hard Drive to USB 3.0 Cable | In Stock | £23.52 |
