This USB duplicator and eraser lets you clone or erase up to seven USB flash drives, without a host computer connection. This means you can work more efficiently and manage larger batches of USB drives, saving time and effort.
The standalone USB duplicator and eraser is perfect for IT professionals and system administrators in corporate, education, marketing, or sales environments.
Efficient 1:7 drive duplication
The duplicator lets you copy up to seven drives simultaneously, and offers both synchronous and asynchronous duplication, with high speeds. The asynchronous feature means you can remove and replace USB storage devices while other copies continue to run. The eraser/duplicator offers two modes of duplication: system and file and whole file. -
Erase multiple USB drives simultaneously
The drive duplicator/eraser lets you erase up to seven flash drives at the same time, so it's easy to clean large batches of USB drives for reuse. The flash drive duplicator features three modes of erasing: quick erase, single pass erase, and multi-pass erase. -
Designed for ease of use
The flash drive duplicator and eraser supports USB 3.0, USB 2.0 and USB 1.1 flash drives, providing an easy and cost-effective way to re-use and re-purpose your USB drives. It features a robust metal housing and a compact, standalone design that makes it the perfect desktop companion. The duplicator/eraser also has an LCD display that makes it easy to monitor erasing and duplication to ensure completion.
- StarTech.com USB Duplicator - 1:7 - USB Flash Drives - Flash Drive Duplicator (USBDUPE17) - USB drive duplicator - TAA Compliant
- Black
- Max Supported Capacity
- 2 TB
- Installed Devices / Modules Qty
- 7 (max)
- Duplication Speed
- 1.5 GBpm
- Localisation
- North America, Japan, United Kingdom, Europe, Australia, New Zealand
- Built-in Devices
- Status LCD
- Power
- AC 120/230 V
- TAA Compliant
- 16 cm x 19 cm x 3.46 cm
- 1 kg
- 2-year warranty
- Duplication Speed
- 1.5 GBpm
- Enclosure Colour
- Black
- Localisation
Chassis
- Built-in Devices
- Status LCD
- Supported Devices / Modules Qty
- 7
Storage
- 2 TB
- 8 x USB 2.0 - 4 pin USB Type A
- 8 LED indicators, Xilinx Spartan XC3S700A chipset, buffer 128 MB
- MTBF
- 8760 hours
- FCC, RoHS, RCM, WEEE
- TAA Compliant
- Power Device
- 1 x external power adapter
- Voltage Required
- AC 120/230 V
- 108 Watt
- 16 cm
- 19 cm
- 3.46 cm
- 1 kg
- Limited warranty - 2 years
- 5 °C
- 45 °C
- 20 - 80%
StarTech.com USB 3.0 to SATA Hard Drive Docking Station for 2.5/3.5 HDD | In Stock | £43.30 |
StarTech.com 6in USB 2.0 Extension Adapter Cable A to A - M/F | In Stock | £4.92 |
StarTech.com 4 Bay USB 3.0 eSATA to SATA Standalone 1:3 HDD Hard Drive Duplicator Dock | In Stock | £416.04 |
StarTech.com Standalone 2.5 / 3.5" SATA Hard Drive Duplicator and Eraser w/ High Duplication Speed | In Stock | £305.05 |
StarTech.com USB 3.0 SATA III Hard Drive Docking Station SSD / HDD with UASP | In Stock | £38.06 |
StarTech.com Standalone 1:5 USB Flash Drive Duplicator and Eraser | In Stock | £377.25 |
StarTech.com Flash Card Reader - USB-C | In Stock | £24.29 |
StarTech.com USB Duplicator and Eraser 1:15 | In Stock | £1,016.90 |
StarTech.com USB Duplicator and Eraser 1:7 | In Stock | £646.75 |
StarTech.com M.2 SATA & M.2 NVMe Duplicator | In Stock | £751.08 |
