StarTech.com Flash Card Reader - USB-C
Quicklinx: CHN6WS00 Mfr#: FCREADU3C
41 In Stock
£24.29 ex VAT
£29.14 inc VAT
Access data on a wide range of memory cards using your USB-C enabled mobile device or computer. Ideal for creative professionals, this multi-card reader/writer saves you time and helps you work more efficiently when working with a wide variety of flash media, letting you quickly transfer and back-up files. It supports SD (Secure Digital), microSD, and CompactFlash cards, and connects to the USB-C port on your tablet, smartphone, laptop or desktop computer.
The multi-card reader makes it easy to offload photos, video, and other files you've saved on your memory cards, providing fast access through USB 3.0 (also known as USB 3.1 Gen 1) with file transfer speeds up to 5Gbps. The reader increases workflow efficiency for creative professionals such as photographers and videographers. It helps to increase your productivity by saving you time when offloading raw images or editing video and photos, and backing up files.
The card reader is also backward compatible with USB 2.0, ensuring compatibility with older systems.
This multi-card flash reader gives you the flexibility and convenience of accessing multiple types of memory cards. It gives you read and write access to virtually any format of flash media card from your digital cameras or video cameras, with support for SD, SDHC (Secure Digital High Capacity), SDXC (Secure Digital Extended Capacity), microSD and CompactFlash cards. You can easily review files or back up and archive data from your smartphone, tablet, laptop or other USB Type-C enabled device. The three memory card slots for SD, microSD, and CompactFlash cards are all hot swappable, for additional flexbility.
The card reader gives you a portable solution for accessing a wide variety of memory cards anywhere you go. With its small form factor, it fits easily into your pocket, backpack, briefcase or laptop bag. The integrated USB Type-C cable lets you quickly connect to a computer or pack it up quickly when you're done using it, without having to carry an additional cable with you. The card reader is powered directly from the USB port and supports plug-and-play installation, with no driver or software installation required.
  • Fast data transfers to increase workflow efficiency
    The multi-card reader makes it easy to offload photos, video, and other files you've saved on your memory cards, providing fast access through USB 3.0 (also known as USB 3.1 Gen 1) with file transfer speeds up to 5Gbps. The reader increases workflow efficiency for creative professionals such as photographers and videographers. It helps to increase your productivity by saving you time when offloading raw images or editing video and photos, and backing up files. The card reader is also backward compatible with USB 2.0, ensuring compatibility with older systems.
  • Supports a wide variety of flash media for flexible use
  • Convenient portability
    The card reader gives you a portable solution for accessing a wide variety of memory cards anywhere you go. With its small form factor, it fits easily into your pocket, backpack, briefcase or laptop bag. The integrated USB Type-C cable lets you quickly connect to a computer or pack it up quickly when you're done using it, without having to carry an additional cable with you. The card reader is powered directly from the USB port and supports plug-and-play installation, with no driver or software installation required. The FCREADU3C is backed by a StarTech.com 2-year warranty and free lifetime technical support.
StarTech.com USB 3.0 Flash Memory Multi-Card Reader/Writer with USB-C - SD microSD and CompactFlash Card Reader w/ Integrated USB-C Cable (FCREADU3C) - card reader - USB 3.0
Card reader - external
Supported Memory Cards
CompactFlash Card type I, CompactFlash Card type II, MultiMediaCard, SD Memory Card, microSD, SDHC Memory Card, microSDHC, SDXC Memory Card, microSDXC
Host Interface
USB 3.0
Black & silver
Host Interface
USB 3.0
Black & silver
6.4 cm
6.8 cm
1.4 cm
67 g
Memory Card
(max)
Required Ports
1 x 24 pin USB-C
FCC, RoHS
CHN6 StarTech.com 4 Port USB 3.0 Hub - USB-C Hub In Stock £30.59
CHN6 StarTech.com Flash Card Reader - USB-C In Stock £24.29
CHN6 StarTech.com 2m USB 3.0 C Cable w/ PD (3A) In Stock £14.36
CHN6 StarTech.com CFast Card Reader - USB 3.0 In Stock £22.38
CHN6 StarTech.com USB 3.0 SD/microSD Card Reader In Stock £9.52
CHN6 StarTech.com CFast Card Reader - USB-C In Stock £28.39
CHN6 StarTech.com USB Multi-Media Card Reader In Stock £17.10
CHN6 StarTech.com CFexpress Type B Card Reader In Stock £19.18
CHN6 StarTech.com SD Express Card Reader In Stock £31.70
Supported Formats: CompactFlash Card type I
Supported Formats: CompactFlash Card type II
Supported Formats: SD Memory Card
Supported Formats: SDHC Memory Card
Supported Formats: MultiMediaCard
Supported Formats: microSD
Supported Formats: microSDHC
Supported Formats: microSDXC
Supported Formats: SDXC Memory Card
Interface: USB 3.0
