StarTech.com USB Duplicator and Eraser 1:15
Quicklinx: D9KRWS00 Mfr#: USBDUPE115
Form Factor: [N/A]
Capacity: 2TB
Interface: USB 2.0
Select:
Hurry, only 3 left in stock!
£1,045.73 ex VAT
£1,254.87 inc VAT
This USB duplicator and eraser lets you clone or erase up to 15 USB flash drives, without a host computer connection. This means you can work more efficiently and manage larger batches of USB drives, saving time and effort.
The standalone USB duplicator and eraser is perfect for IT professionals and system administrators in corporate, education, marketing, or sales environments.
  • Efficient 1:15 drive duplication
    The duplicator lets you copy up to 15 drives simultaneously, and offers both synchronous and asynchronous duplication, with speeds up to 1.5GB per minute. The asynchronous feature means you can remove and replace USB storage devices while other copies continue to run. The duplicator offers two duplication modes, system and file and whole file.
  • Erase multiple USB drives simultaneously
    The drive duplicator/eraser lets you erase up to 15 flash drives at the same time, so it's easy to clean large batches of USB drives for reuse. The flash drive duplicator features three modes of drive erasing: quick erase, single pass erase, and multi-pass erase (meets DoD standards).
  • Designed for ease of use
    The flash drive duplicator and eraser supports USB 3.0, USB 2.0 and USB 1.1 flash drives, providing an easy and cost-effective way to re-use and re-purpose your USB drives. It features a robust metal housing and a compact, standalone design that makes it the perfect desktop companion. The flash drive eraser/copier also has an LCD display that makes it easy to monitor erasing and duplication to ensure completion. The USBDUPE115 is TAA compliant and backed by a StarTech.com 2-year warranty and free lifetime technical support.
StarTech.com Standalone USB Duplicator - USB Duplicator and Eraser - USB 3.0, 2.0, 1.1 - 1:15 USB Flashdrive - USB Thumb Drive (USBDUPE115) - USB drive duplicator - TAA Compliant
Max Supported Capacity
2 TB
15 (max)
Duplication Speed
1.5 GBpm
North America, Japan, United Kingdom, Europe, Australia, New Zealand
Built-in Devices
Status LCD
AC 120/230 V
TAA Compliant
34.5 cm x 16 cm x 3.46 cm
1.8 kg
Duplication Speed
1.5 GBpm
Enclosure Colour
Chassis
Built-in Devices
Status LCD
Supported Devices / Modules Qty
15
Storage
2 TB
16 x USB 2.0 - 4 pin USB Type A
Xilinx Spartan XC3S700A chipset, buffer 128 MB, 16 LED indicators
MTBF
8760 hours
FCC, RoHS, RCM, WEEE
TAA Compliant
1 x external power adapter
AC 120/230 V
150 Watt
34.5 cm
16 cm
3.46 cm
1.8 kg
5 °C
45 °C
20 - 80%
D9KR StarTech.com USB 3.0 to SATA Hard Drive Docking Station for 2.5/3.5 HDD In Stock £40.39
D9KR StarTech.com 6in USB 2.0 Extension Adapter Cable A to A - M/F In Stock £4.59
D9KR StarTech.com 4 Bay USB 3.0 eSATA to SATA Standalone 1:3 HDD Hard Drive Duplicator Dock In Stock £409.75
D9KR StarTech.com 1:2 Standalone USB 2.0 Flash Drive Duplicator and Eraser In Stock £118.08
D9KR StarTech.com Standalone 2.5 / 3.5" SATA Hard Drive Duplicator and Eraser w/ High Duplication Speed In Stock £287.21
D9KR StarTech.com USB 3.0 SATA III Hard Drive Docking Station SSD / HDD with UASP In Stock £39.43
D9KR StarTech.com USB 3.0 Dual Hard Drive Docking Station with UASP for 2.5/3.5in SSD / HDD – SATA 6Gbps In Stock £59.05
D9KR StarTech.com Standalone 1:5 USB Flash Drive Duplicator and Eraser In Stock £441.84
D9KR StarTech.com Flash Card Reader - USB-C In Stock £25.01
D9KR StarTech.com USB Duplicator and Eraser 1:15 In Stock £1,045.73
D9KR StarTech.com USB Duplicator and Eraser 1:7 In Stock £661.43
D9KR StarTech.com M.2 SATA & M.2 NVMe Duplicator In Stock £691.38
Form Factor: [N/A]
Capacity: 2TB
Interface: USB 2.0
Price Range Ex VAT: £1000 - £1500
