Connect your USB Type-C laptop to a VGA display and a USB Type-A peripheral device, plus power and charge your laptop. This universal multifunction adapter lets you expand the connectivity of your laptop or MacBook through USB-C . You can connect your laptop to a VGA display, while also connecting a traditional USB 3.0 device. And, when coupled with your laptop's power adapter, the multiport adapter delivers power to help charge and maintain your laptop's battery.
This compact USB-C adapter is a vital accessory for virtually any USB-C equipped laptop, MacBook, or Chromebook . It's extremely portable, with a lightweight, small-footprint design that tucks neatly into your laptop bag or carrying case.
The rugged multifunction adapter meets the tough demands of travelers. Now you can rest assured knowing your adapter is ready when you are.
If you have a VGA display or projector, you can connect it to this combo adapter to create a dual-screen workstation, comprised of your laptop's display and the additional external display or projector. With an additional display, you can get more work done at once by multitasking more efficiently.
Whether you're delivering a presentation in a boardroom or looking to add a display to your existing laptop workstation, this adapter is a must-have accessory.
Because this versatile adapter supports USB Power Delivery, you can power and charge your laptop through its USB Type-C port. Simply connect the adapter to your laptop's USB-C port, and then connect your laptop's power adapter to the multifunction adapter.
By using a single power adapter to power your laptop and the adapter, instead of using multiple adapters, you can travel lighter and more conveniently. Plus, you can reduce cable clutter in your work area.
Unlike some proprietary laptop adapters designed only to work with specific laptop models, this universal adapter works with multiple brands. All you need is a laptop's USB-C port that supports DP alt mode and USB Power Delivery, and you can be up and running quickly. With universal support, you can use this adapter with different laptops now, or in the future. Plus, it's compatible with Thunderbolt 3 ports.
This USB-C to VGA multifunction adapter features a USB 3.0 port that's backward compatible with older USB devices. It's perfect for data transfers, syncing, or charging your mobile device.
For optimal video performance, use with StarTech.com verified cables: 10 ft Mini DisplayPort to DisplayPort 1.2 Adapter Cable; 6 ft Mini DisplayPort to DisplayPort 1.2 Adapter Cable; 3 ft Mini DisplayPort to DisplayPort 1.2 Adapter Cable; 6 ft Mini DisplayPort 1.2 Cable; 3 ft Mini DisplayPort 1.2 Cable; 3m (10 ft) White Mini DisplayPort to DisplayPort 1.2 Adapter Cable; 2m (6 ft) White Mini DisplayPort to DisplayPort 1.2 Adapter Cable; 1m (3 ft) White Mini DisplayPort to DisplayPort 1.2 Adapter Cable.
- StarTech.com USB-C VGA Multiport Adapter - USB-A Port - with Power Delivery (USB PD) - USB C Adapter Converter - USB C Dongle (CDP2VGAUACP) - docking station - USB-C / Thunderbolt 3 - VGA
- Product Type
- Docking station
- Docking Interface
- Video Interfaces
- VGA
- 4 cm x 8 cm x 1.5 cm
- 39 g
- Black
- 3-year warranty
- Product Type
- Docking station
- 4 cm
- 8 cm
- 1.5 cm
- 39 g
- Enclosure Colour
- Black
Video
- Max Resolution Details
- 2048 x 1280 - 60 Hz
- USB 1.1, USB 2.0, USB 3.0, USB 3.1 Gen 1
- 1 x USB-C 3.1 Gen 1 with Power Delivery (60W) - 24 pin USB-C (power only) , 1 x display / video - VGA - 15 pin HD D-Sub (HD-15) , 1 x SuperSpeed USB 3.0 - 9 pin USB Type A
- Cables Included
- 1 x USB-C cable - integrated - 14 cm
- USB powered, 60W power delivery
- FCC, RoHS, USB Power Delivery 2.0, UASP (USB Attached SCSI Protocol)
- Limited warranty - 3 years
- Shipping Width
- 14.5 cm
- Shipping Depth
- 17.1 cm
- Shipping Height
- 3.4 cm
- Shipping Weight
- 109 g
StarTech.com USB-C Multifunction Adapter | In Stock | £48.02 |
StarTech.com USB-C to 4K HDMI Adapter with Power Delivery | In Stock | £46.74 |
StarTech.com USB-C to VGA Adapter with PD | In Stock | £37.34 |
StarTech.com USB-C Adapter - PD - Silver | In Stock | £27.52 |
StarTech.com 4m USB 2.0 C Cable w/ PD (5A) | In Stock | £17.50 |
StarTech.com 2m USB 3.0 C Cable w/ PD (3A) | In Stock | £19.20 |
StarTech.com 1m USB 3.1 C Cable w/ PD (5A) | In Stock | £25.23 |
StarTech.com USB C Adapter - 4K HDMI, GbE | In Stock | £26.78 |
StarTech.com USB-C Multiport Adapter - DVI | In Stock | £25.92 |
StarTech.com USB-C Multiport Adapter - SD - Power Delivery - 4K HDMI - GbE - 2x USB 3.0 | In Stock | £69.47 |
StarTech.com USB C VGA Multiport Adapter | In Stock | £35.75 |
StarTech.com USB-C Multiport Adapter Docking Station | In Stock | £124.67 |
StarTech.com USB-C Multiport Adapter HDMI - SD Reader - 2xA 1xC - PD3.0 | In Stock | £60.40 |
StarTech.com USB-C Multiport Adapter with Unfolding Cable - HDMI1.4 - USB | In Stock | £38.52 |
StarTech.com USB-C Adapter with HDMI & VGA | In Stock | £33.69 |
StarTech.com USB-C Multiport Adapter, 4K HDMI or VGA, Type-C Mini Dock | In Stock | £61.81 |
StarTech.com USB C Multiport Adapter - USB-C to 4K HDMI/PD/USB -Mini Dock | In Stock | £23.87 |
StarTech.com USB C Multiport Adapter 4K | In Stock | £32.46 |
StarTech.com USBC Multiport Adapter 4K HDMI | In Stock | £27.44 |
StarTech.com USB-C Multiport Adapter HDMI | In Stock | £60.08 |
StarTech.com USB C Multiport Adapter | In Stock | £23.87 |
StarTech.com Multiport Adapter HDMI/VGA | In Stock | £59.05 |
StarTech.com USB C Multiport Adapter, 4K | In Stock | £33.46 |
StarTech.com USB C Multiport Adapter 4K | In Stock | £47.66 |
StarTech.com USBC Multiport Adapter 4K 60Hz | In Stock | £45.76 |
StarTech.com USB C Multiport Adapter 2 HDMI | In Stock | £66.71 |
StarTech.com USBC Multiport Adapter 4K 60Hz | In Stock | £30.95 |
StarTech.com USB C Dock DP 4K30Hz or VGA | In Stock | £94.14 |
StarTech.com USB-C Multiport Adapter | In Stock | £70.29 |
StarTech.com USB C Multiport Adapter | In Stock | £85.11 |
StarTech.com USB-C Multiport Adapter, HDMI | In Stock | £33.04 |
StarTech.com USB-C Multiport Adapter, HDMI | In Stock | £29.25 |
StarTech.com USB-C Triple Monitor Docking Station | In Stock | £179.82 |
StarTech.com USB-C Multiport Adapter - HDMI/DP | In Stock | £43.01 |
StarTech.com USB-C Multiport Adapter - HDMI/VGA | In Stock | £28.05 |
StarTech.com USB-C Speakerphone Dock | In Stock | £81.07 |
StarTech.com USB-C Triple-Monitor Adapter | In Stock | £90.11 |
StarTech.com USB-C/USB-A Multiport Adapter | In Stock | £51.56 |
StarTech.com USB-C Triple-Monitor Adapter | In Stock | £94.35 |
