USB Type-C Multiport Adapter | 4K @ 30Hz HDMI | 2x USB-A | SD & MicroSD Card Reader | 100W Power Delivery Passthrough
This USB-C multiport adapter with HDMI turns your MacBook Pro, Dell XPS, or other USB-C laptops into a workstation, anywhere you go. The USB Type-C multiport adapter provides 4K HDMI video output, two USB 3.2 Gen 2 Type-A (10Gbps) ports, and a USB Type-C port (power/data), all through one connection to your laptop's USB-C or Thunderbolt 3 port. Plus, it offers advanced charging through USB Power Delivery 3.0 and an extra-long attached 12-inch (30 cm) host cable for an extended reach to offer more set up flexibility.
Enhance Productivity
The portable docking station connects your laptop to a 4K 30Hz HDMI monitor (3840 x 2160p) to create a powerful workstation. It can also connect to an ultrawide monitor.
Connect Your Devices
The USB-C to USB 3.2 Gen 1 hub gives you two USB-A ports one and a USB-C port (shared power/data) to connect your latest and legacy USB devices.
Built-In SD Card Reader
Access your multimedia content with ease. The multiport adapter provides direct access to your SD, SDHC and SDXC memory cards or microSD (uSD) cards.
Charge Your Laptop and Peripherals
With support for USB PD 3.0 (up to 100W), the USB Type-C multiport adapter lets you power and charge your laptop, and power your peripherals when connected to a USB-C power adapter. PD 3.0 features Fast Role Swap to prevent USB data disruption when you switch power sources (USB-C power adapter to bus power).
The DKT30CHSDPD is backed by a StarTech.com 3-year warranty and free lifetime technical support.
Note: To ensure full adapter functionality, your laptop's USB-C port must support USB Power Delivery.
The portable docking station connects your laptop to a 4K 30Hz HDMI monitor (3840 x 2160p) to create a powerful workstation. It can also connect to an ultrawide monitor. -
The USB-C to USB 3.2 Gen 1 hub gives you two USB-A ports one and a USB-C port (shared power/data) to connect your latest and legacy USB devices. -
Access your multimedia content with ease. The multiport adapter provides direct access to your SD, SDHC and SDXC memory cards or microSD (uSD) cards. -
With support for USB PD 3.0 (up to 100W), the USB Type-C multiport adapter lets you power and charge your laptop, and power your peripherals when connected to a USB-C power adapter. PD 3.0 features Fast Role Swap to prevent USB data disruption when you switch power sources (USB-C power adapter to bus power). The DKT30CHSDPD is backed by a StarTech.com 3-year warranty and free lifetime technical support. Note:?To ensure full adapter functionality, your laptop's USB-C port must support USB Power Delivery.
- StarTech.com USB C Multiport Adapter, USB-C to 4K 30Hz HDMI, 100W Power Delivery Pass-through, SD/MicroSD Slot, 3-Port USB 3.0 Hub, USB Type-C Mini Dock, 12" (30cm) Long Attached Cable - Thunderbolt 3 Compatible (DKT30CHSDPD) - docking station - USB-C / Thunderbolt 3 - HDMI
- Product Type
- Docking station
- Docking Interface
- Video Interfaces
- HDMI
- 5.2 cm x 1.4 cm
- 98 g
- Power
- Power Provided
- 3-year warranty
- Product Type
- Docking station
- 5.2 cm
- 1.4 cm
- 98 g
Video
- Max Resolution Details
- 3840 x 2160 - 30 Hz , 3440 x 1440 - 60 Hz
- USB 3.2 Gen 2
- Expansion Slots
- 1 (total) / 1 (free) x SD / MMC Memory Card , 1 (total) / 1 (free) x microSD
- 1 x USB 3.1 Gen 2 - 9 pin USB Type A , 1 x SuperSpeed USB 3.0 with Battery Charging 1.2 - 9 pin USB Type A , 1 x display / video - HDMI - 19 pin HDMI Type A , 1 x USB-C with Power Delivery (100 W) - 24 pin USB-C
- Input Device
- SD card reader, microSD card reader
- Cables Included
- 1 x USB-C cable - integrated - 30 cm
- 100W power delivery
- FCC, RoHS, USB Battery Charging Specification Rev. 1.2, USB Power Delivery 3.0
- OS Required
- Android, Google Chrome OS, Apple macOS High Sierra 10.13, Apple macOS Mojave 10.14, Apple macOS Catalina 10.15, Apple iPadOS, Apple macOS Big Sur 11.0, Apple macOS Monterey 12.0, Windows 8 / 10 / 11, Apple macOS Ventura 13.0
- Limited warranty - 3 years
- Shipping Width
- 14.2 cm
- Shipping Depth
- 17 cm
- Shipping Height
- 3 cm
- Shipping Weight
- 134 g
- 0 °C
- 70 °C
StarTech.com USB C Dock DP 4K30Hz or VGA | In Stock | £115.87 |
